Date/Time: Fri, 18 Sep 2026 04:52:44 +0000
SPREAD SHEET AUTOMATION ?
View Count: 1017
| [2016-03-16 14:54:21] |
| User367949 - Posts: 25 |
What is the correct way to add this in spreadsheets For the spread sheet automation so every 2 wins its adds 1 contract to normal position size. And on the first loss it resets it to the normal position size eg 1 contract? What is the way of password protection and security is there available for spreadsheets ? Thanks |
| [2016-03-16 17:35:24] |
The question is not within the scope of our support. You need to refer to the documentation: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php There is no password protection supported for Spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 17:36:38] |
How hard is to help someone trying to use your platform by going this formula is the way you would do it ?
| [2016-03-16 17:37:37] |
I get the alerts and automation its the specifics not sure on how to add 1 contract after 2 wins and reset after a loss to normal size
Date Time Of Last Edit: 2016-03-16 17:38:12
| [2016-03-16 18:05:32] |
You will need to contact a programmer to do this: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html It is clearly not with the scope of our support to provide this level of help. And yes, this is hard to help with this. This could be many hours of help. Also, Spreadsheets are really not the proper way to do this. You need to use ACSIL: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-16 18:07:09
| [2016-03-16 18:11:28] |
Ok is it possible to have a simple formula in spread sheets that add 1 contract after 2 win and resets it to 1 after a loss? that's what I'm asking as I would like to see how good your spreadsheet automation is |
| [2016-03-16 18:41:40] |
This is not simple. And as a matter of policy we do not provide formula programming help. Also, when it comes automated trading, if you cannot determine the formulas, it makes no sense for us to be helping with them. Automated trading is serious and you need to fully understand what it is you are doing and be responsible for it. Refer to post #5 above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 18:50:28] |
I know its serious that's why I have come see what the advanced spreadsheets studies can do. I know the formula! you are having trouble answering the question and determining is it possible in spreadsheets? For a formula to add 1 contract after 2 wins in a row and reset after a loss - that's the question if your a engineer and code this platform you would know this? Watched a great webinar with Anthony from Sierra Charts showing what you can do with it! So why talk down to your customers who are just learning how to use your platform? |
| [2016-03-16 19:03:00] |
We do not think this is easy to do with Spreadsheets and you need to use ACSIL as we explained in post #5: Automated Trading From an Advanced Custom Study You really are missing the point of what we are trying to say. Refer to our support policies here: Support Board Posting Information: General Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 19:42:12] |
The difficulty with spreadsheets is keeping track of past Profit and Loss values for prior Trades. Using ACSIL you have access to all of this information easily. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 19:54:25] |
Im not a coder and I would like to be able to automate my strategy's myself hence why I would like to see if it is possible
