Date/Time: Sun, 20 Sep 2026 23:35:31 +0000
Copy chart drawing from one Sierra instance to another
View Count: 2447
[2016-03-16 14:29:46]
User36865 - Posts: 10
It is possible to copy (link in real time) chart drawing from one Sierra Chart to another ? I have 2 installations on same computer (C:\SierraChart and C:\SierraChart2). One opened on first monitor and second on second monitor. When I draw line in first sierra I wan to display it on secondary SC installation.
Thank you.
[2016-03-16 16:49:38]
This is not supported.
[2022-04-17 18:38:23]
HumblyTrading - Posts: 222
Hello SC Team,
It would be very powerful for those of us with a lot of chart markups to be able to copy them to another instance.
For example, I take swing positions using one brokerage account. However, I would scalp up and down within that using another.
The problem is, I can't copy 100's of lines, rectangles and text over quickly enough.
Could we set this as a user request?
Also, is there a workaround to use a 3rd party service which would copy a specific file between the instances in continuous real-time? I have such a software, but I'm not sure if there is a file inside of the data file that could be constantly used in the master instance to overwrite the sub-instance.
Thanks!
Mike
[2022-04-23 01:40:25]
Hello SC Team,
Any update on the above question?
Thanks!
[2022-04-23 09:17:04]
There are definitely no plans at all to copy chart drawings between Sierra Chart instances.
We do not know about any third-party tools to do this.
Date Time Of Last Edit: 2022-04-23 09:17:15
[2022-04-23 19:24:14]
User99735 - Posts: 234
Hi All,
I have ready master/slave studies, which copy drawings across Sierra instances. Do get in touch.
Vivek
[2022-10-21 12:37:04]
User758499 - Posts: 10
Why would you not implement this? This would be unbelievably convenient for those of us who use multiple screens with one instance on each
