Date/Time: Fri, 27 Dec 2024 01:58:35 +0000
how to change this color
View Count: 741
[2016-03-16 14:16:38] |
User20450 - Posts: 330 |
how can i change the color of the yz pointer ?
2016-03-16_10-15.jpg / V - Attached On 2016-03-16 14:16:36 UTC - Size: 21.68 KB - 293 views |
[2016-03-16 14:52:50] |
found it , thanks
[2016-03-16 17:47:27] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
