Date/Time: Fri, 27 Dec 2024 00:30:23 +0000
Overnight and Asian Sunday/Monday sessions High and Low plotted on RTH chart
View Count: 2007
[2016-03-16 10:04:10]
User787778 - Posts: 142
Using Initial Balance study, I am able to plot the overnight/Asia high and lows on a regular RTH chart from Tuesday to Friday, but not for Sunday/Monday. Only the Sunday values are plotted.
Using Daily OHLC for the current day(set to the overnight session) on a different chart and then using a study overlay on the RTH chart does not work.
[2016-03-16 17:29:13]
Use the High/Low for Time Period - Extended study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s246
The very first step is to get the result from the High/Low for Time Period-Extended study working correctly on the chart containing the full 24 hours of data. Until that is done, do not overcomplicate it with an overlay.
Here is the documentation for the Study/Price Overlay study:
https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php
Date Time Of Last Edit: 2016-03-16 17:30:14
[2016-03-28 20:56:37]
kinghat - Posts: 120
i am also having trouble with getting monday to include sundays trade action in an overnight high/low using the High/Low for Time Period - Extended study. i have tried a full session from open to close and a day with an evening session. screenshots below.
imagegk4eLzS.png / V - Attached On 2016-03-28 20:56:13 UTC - Size: 116.92 KB - 293 views
imageSierraChart_2016-03-28_15-55-07.png / V - Attached On 2016-03-28 20:56:17 UTC - Size: 117.96 KB - 305 views
[2016-03-29 08:53:57]
I had that problem when I was using Daily OHLC, but after changing to High/Low for time period Extended, I got the correct period identity.
Date Time Of Last Edit: 2016-03-29 15:11:44
attachmentHigh Low.docx - Attached On 2016-03-29 08:53:47 UTC - Size: 56.48 KB - 347 views
[2016-03-29 10:10:22]
In response to post #3, look over the documentation we have written here about this:
https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#UnderstandingTradingDayDatesBasedOnSessionTimes
This is our first draft and has not been thoroughly reviewed, but it explains how the study works with bar Date-Times and the Session Times.
Date Time Of Last Edit: 2016-03-29 10:38:41
[2016-03-29 13:53:43]
User787778 it shows the file you posted as 'Private File' were you trying to post something public there? i just cant seem to get it to work correctly, even after reading it. sorry for being thick headed.
