Date/Time: Fri, 27 Dec 2024 02:06:22 +0000
Error loading Open Trader.cht file
View Count: 1323
[2016-03-15 22:49:09]
User461267 - Posts: 3
Hi
I am trying to get a .cht file to load from Open Trader.
I can load the file but no data is being displayed.
I have attached the file to this post.
Terry
attachmentOpenTrader (5).cht - Attached On 2016-03-15 22:48:10 UTC - Size: 1.41 MB - 351 views
[2016-03-16 02:14:40]
The most likely problem is that the Symbol of the charts need to be changed to match the Service you are using.
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol
