Date/Time: Fri, 27 Dec 2024 02:20:35 +0000
TRADING SYSTEM
View Count: 658
[2016-03-15 19:05:45] |
User82615 - Posts: 106 |
HELLO LET'S SEE IF YOU CAN HELP ME WITH THIS: I AM DESIGNING A TRADING SYSTEM IN ACSIL THAT HAS SOME SPECIFICACTIONS AND I DON'T KNOW IF IT CAN BE DONE : IT WORKS LIKE THIS : ONCE THE SYSTEM IS PLACED IN THE CHART , TO SEND THE NEXT ORDER THE SYSTEM FIRST NEED TO DETECT IF THE LAST TRADE OF THE SYSTEM WAS A WIN OR A LOSE THEN THE SYSTEM WILL LAUNCH ONE ORDER OR ANOTHER. SO MY QUESTION IS , IS THERE A WAY TO PROGRAM IN ACSIL A SYSTEM THAT DETECTS IF THE LAST TRADE OF THE SYSTEM WAS A LOSE TRADE OR A WIN TRADE? IF SO COULD YOU PLEASE GUIDE ME HOW TO DO THIS? THANK YOU VERY MUCH FOR YOUR HELP |
[2016-03-16 03:34:38] |
You can use this function: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#scGetTradeListEntry Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
