Date/Time: Fri, 27 Dec 2024 02:34:31 +0000
Plotting a study across charts
View Count: 623
[2016-03-15 15:18:32] |
Adam - Posts: 141 |
Hi I have some study's I use on my primary session only chart such at Pivots and i want to have them plotted on another chart. is this possible. it means I can have more data on one chart and minimise the others Adam |
[2016-03-15 16:51:37] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
