Date/Time: Sun, 27 Sep 2026 02:54:27 +0000
Automatically create 3 TPO's per day
View Count: 1575
| [2016-03-15 08:17:14] |
| Adam - Posts: 141 |
Hi I've been using windotrader blue for a particular tpo time frame set up but I can't cope with the instability and I'm hoping I can move this to you guys. I want to have a TPO chart (volume and TPO if possible) that creates 3 TPO's per day (euro session 8am-2pm, NYC 2pm to 10pm and Tokyo 10pm to 8am). These would ideally be three separate TPO's with their own Initial balance. Can this be done? |
| [2016-03-15 09:16:56] |
Sierra Chart supports a maximum of two TPO Profiles per day unless you split one manually. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#DayEveningSeparateProfiles https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#SplitMerges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-15 10:13:12] |
| Adam - Posts: 141 |
Whats the workload to get 3 splits? can i have my developer do this or does it need to be done by SC? |
| [2016-03-15 18:56:28] |
Please check back with us in about 2 to 3 months. This must be done by us and nobody else. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 01:47:07] |
| User265175 - Posts: 3 |
+1 that would be fantastic and a committed supporter.
