Date/Time: Fri, 27 Dec 2024 02:37:13 +0000
rectangle highlight drawing centered on sc.Index and price level
View Count: 926
[2016-03-14 22:12:38]
@sstfrederik - Posts: 404
I would like to draw a rectangle around a bar or part of a bar. Similar how the highlight feature in the Numbers Bars study is performed. When using the drawing tool it starts at the center of a bar, I would like to start and end at the edge of the bar index. Is this possible? Any other way of doing this?
thanks.
[2016-03-15 09:26:37]
You cannot do this with Chart Drawing Tools, but there are various Study Subgraph Draw Styles which you can use:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle
