Date/Time: Fri, 20 Sep 2024 01:13:09 +0000
Newbie Chart Trading P&L Display query
View Count: 1773
[2013-07-03 10:15:07] |
User53259 - Posts: 1 |
Hello, Forgive the beginners question but can someone point me in the right direction so that I can have the P&L figure on the chart trader display in $US? At the moment it displays as P/L 1.10C where I assume the C stands for currency but it should be $1100. In the chart settings - Main settings Price format is .01 and tick size is also .01 then in - Advanced Settings I have Position Profit/Loss set as Currency Value and in General Trade settings I have Common Profit/Loss Currency set as USD. What am I missing? Thank you |
[2013-07-10 04:14:44] |
This may not be possible depending upon the symbol you are trading. Please refer to this help topic for details about this: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-10 04:14:56
