Date/Time: Fri, 27 Dec 2024 02:18:51 +0000
Sound Alert on Symbol change
View Count: 906
[2016-03-14 19:10:25] |
AP - Posts: 117 |
Is there a way to quieten the sound alert on every change in symbol?
[2016-03-14 21:07:38] |
The chart and/or studies must have an alert which is evaluating to TRUE when you change the symbol. You can enable Global Settings >> Mute All Alert Sounds.
[2016-03-14 22:43:39] |
AP - Posts: 117 |
Yeah, there is a sound alert that goes off in checking if the C>$200. Even if I get rid off all the studies and start a new chart altogether, it does not go. That tells me it is a bug. For now, I will work with Muting all sound alerts; but please see if you can address it in your future releases. |
[2016-03-14 22:54:11] |
You have not convinced us there is a bug and we know there is not. The source of the sound can be seen in Window >> Alerts Manager. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-14 22:58:33] |
AP - Posts: 117 |
I saw the Alerts Manager and that is how I informed you that there is a sound alert that goes off where it checks - Alert - Chart: AMZN 5 Min #1 | Formula: =C>200 is TRUE. | Last Price: 574.71 | Bar Start Time: 2016-03-14 15:40:00 | Alert: Alert 1 And in checking the chart settings and all the studies attached to it - there is no such alert grafted in it. |
[2016-03-14 23:13:38] |
This Alert Formula is from chart #1.
[2016-03-14 23:34:12] |
AP - Posts: 117 |
Even I can see that in reading "#1" - but when I go to the chart - I just do not see any formula in it or any of its studies.
[2016-03-14 23:35:05] |
Must therefore be from another Chartbook other than the active Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-14 23:35:26
[2016-03-14 23:39:57] |
AP - Posts: 117 |
There is only 1 chart book open.
