Date/Time: Fri, 27 Dec 2024 01:46:20 +0000
Circular Chart Reference Detected
View Count: 1206
[2016-03-14 18:11:03] |
User395613 - Posts: 9 |
I'm getting a message log now. Something about Chart #1 has tagged chart #3 for full recalculation and Circular Chart Reference detected. What do I do now? Robert Date Time Of Last Edit: 2016-03-14 19:20:12
[2016-03-14 19:17:07] |
i960 - Posts: 360 |
You have two charts that depend on each other meaning there's some kind of overlay, diff, ratio, etc type study on each of the charts that is making a reference to the other chart. It's a warning to let you know that.
[2016-03-14 20:45:25] |
I haven't changed anything in the last month. The charts rolled over to June automatically, I see. Maybe it has to do with the rollover? Will it effect my trading? Doesn't seem to be. Can I ignore it? The charts are working OK. Robert |
[2016-03-14 21:40:44] |
i960 - Posts: 360 |
It's not going to hurt anything but you probably want to check your studies for where the circular reference is occurring.
[2016-03-14 22:15:36] |
Refer to this help topic about it: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.9 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
