Date/Time: Fri, 27 Dec 2024 01:25:42 +0000
FXCM FIX Trading session: Received a Reject
View Count: 995
[2016-03-14 16:47:52] |
Ziklag - Posts: 73 |
All was working well until this Monday when, repeatedly, positions are opened but "attached orders" (loss limit) are rejected ...did anything change over the weekend ...? FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 283. RefTagID = 526. Reference Message Type = E. SessionRejectReason = 15. Text = Out of order repeating group members | 2016-03-14 16:49:56 * FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 399. RefTagID = 526. Reference Message Type = E. SessionRejectReason = 15. Text = Out of order repeating group members | 2016-03-14 17:45:07 * FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 400. RefTagID = 526. Reference Message Type = E. SessionRejectReason = 15. Text = Out of order repeating group members | 2016-03-14 17:45:07 * |
[2016-03-14 17:04:33] |
Apparently something did change on the FXCM side. We need to contact FXCM about this. There are other reports of a problem as well. As a temporary solution uncheck Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-20 00:46:14
[2016-03-20 00:45:57] |
We realized we made a small mistake in the prior message. We meant "uncheck" not check that option. That will solve the problem. We want to start testing of the new connection model for FXCM. Here is more information about this: New Connection Model for FXCM Forex Trading with no Account Minimum. Users Wanted for Testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-20 00:46:51
