Date/Time: Wed, 24 Jun 2026 11:48:54 +0000
Charts not updating with previous contract
View Count: 1012
| [2016-03-14 14:27:12] |
| Willson - Posts: 176 |
Updated to ver 1379 release. Use Transact data. Chartbook using last contract ESH6 does not update. A different Chartbook using ESM6 runs fine. When using the older contract, I get message that Symbol (ESH6) does not exist. I would like to be able to use the older contract as it still trades. Regards |
| [2016-03-14 16:27:11] |
If you are getting an error message that it does not exist, that is originating from the TransAct server.
