Date/Time: Mon, 28 Sep 2026 10:19:16 +0000
MOST SECURE WAY TO HAVE STRATEGY DEVELOPED? PROTECTED WHEN DEPLOYED?
View Count: 1634
| [2016-03-14 14:01:33] |
| User367949 - Posts: 25 |
What is the most secure way to code and protect strategy with Sierra Charts? I am having it coded with a developer so need to understand what steps I need to do so I don't get locked out my strategy etc I understand you can make C++ code very secure with binary code use? Thanks A |
| [2016-03-14 16:22:39] |
Protect it in what way? Compiled C++ code cannot be decompiled back into source code. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-14 16:44:29] |
Protect the logic of the strategy How do I have it developed securely ? |
| [2016-03-14 17:05:43] |
As long as the study/strategy is developed using unmanaged C++ code which it would need to be, it is inherently protected. Nothing special has to be done.
| [2016-03-14 22:13:49] |
Unmanaged C++ code ? How do I ensure dnt get locked out my code and get all the source code ? cheers A |
| [2016-03-14 22:17:02] |
Custom strategies/studies developed for Sierra Chart have to be developed using unmanaged C++ code. Do you have a developer doing the programming for you? They just need to provide you with the source code. As long as you have that, then there is nothing to be concerned with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-14 22:17:53] |
How do I know I have it all ?
| [2016-03-15 08:33:05] |
Source code is contained in a file with a CPP extension. If you have a developer doing the programming, then just make sure they provide you the CPP files. To make sure you have all of them you can compile them through Analysis >> Build Custom Studies DLL: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-15 10:28:30] |
| gomifromparis - Posts: 244 |
The contractor might hold copyrights on his work. From what I understand here : http://asp-software.org/www/misv_resources/business-articles/who-owns-the-code/ you need him to sign an agreement saying it was "work-made-for-hire" "Third, and most significant, a commissioned and copyrightable work will only be considered "work-made-for-hire" owned by the client if the parties have a written agreement signed by the developer that explicitly states that the work is "work-made-for-hire." Date Time Of Last Edit: 2016-03-15 10:28:52
| [2016-03-15 16:57:08] |
ok this helps and other advise ?
