Date/Time: Thu, 26 Dec 2024 11:29:36 +0000
Transact Data
View Count: 755
[2016-03-14 13:33:33] |
ktfroy - Posts: 85 |
Using Transact, Sierra Chart connects but there is no data flow. Are you aware of an issue? |
[2016-03-14 15:31:04] |
We did see an issue ourselves earlier with a problem connecting to the TransAct server for data. There is not a problem currently.
