Date/Time: Fri, 27 Dec 2024 01:56:42 +0000
Bogus error message when signing on to Sierra
View Count: 835
[2016-03-14 10:18:11]
djcurcio - Posts: 236
As of Saturday 0312 I keep getting a Sierra Chart message that I will no longer be getting updates because Windows XP and Vista are no longer supported.
But, I'am running Windows 7. Not Vista or XP
Seems to be an issue as I obviously want to continue to use Sierra.
[2016-03-14 16:18:07]
This does not sound like an error message from Sierra Chart. We do not have a message that says this.
Attach a screenshot of it.
Date Time Of Last Edit: 2016-03-14 16:18:25
[2016-03-16 04:14:17]
I have enclosed 3 screenshots showing the issue.
imagesierra msg 1.PNG / V - Attached On 2016-03-16 04:12:58 UTC - Size: 9.56 KB - 286 views
imagesierra msg 2.PNG / V - Attached On 2016-03-16 04:13:20 UTC - Size: 54.31 KB - 270 views
imagesierra msg 3.PNG / V - Attached On 2016-03-16 04:13:39 UTC - Size: 58.55 KB - 271 views
[2016-03-16 05:03:26]
Those messages have nothing to do with Sierra Chart. Disregard them. They are from your web browser.
[2016-03-16 05:12:43]
Read them carefully - I think they are somehow being generated when Sierra starts as no browser is active when I start Sierra and the message is formatted to look like a Sierra update message.
[2016-03-16 06:01:18]
In any case, Windows XP will continue to be supported.
[2016-03-16 06:22:56]
Suggest you all might want to look into how someone has infiltrated the Sierra startup with a spoofing sierra like update message box. Note that no similar actions occur when I start any other programs. So it is only when I start Sierra from Transact.
