Date/Time: Thu, 26 Dec 2024 11:03:50 +0000
TPO Blocks Misaligned
View Count: 1111
[2016-03-14 08:09:51] |
hanro - Posts: 10 |
Hi guys - Having this misalignment issue with TPO blocks that started today (something to do with DST?). Pls see the attached screenshots. The chart setting is configured to use Global Time Zone. I've configured the Global Time under Global Data/Trade Service Settings to Chicago and refreshed the charts with new data. The chart settings are also shown in the attached screen. Running v1379. Appreciate your advice on this. |
2016-03-14 00_49_37-Sierra Chart 1379 Chartbook-2016JUN.cht .jpg / V - Attached On 2016-03-14 08:00:18 UTC - Size: 746.49 KB - 302 views 2016-03-14 00_48_29-Program Manager.jpg / V - Attached On 2016-03-14 08:03:15 UTC - Size: 558.22 KB - 669 views |
[2016-03-14 08:31:21] |
We think this is due to a change we made to solve an issue with TPO Profile charts when using Include Columns with Data. We are fixing this now and we will have a new release out in about 30 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-14 09:49:19] |
We have released version 1380 which solves this. Follow the instructions here to update: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-14 09:56:20] |
hanro - Posts: 10 |
Confirming 1380 resolves the issue. Grateful for your quick response. |
