Date/Time: Thu, 26 Dec 2024 11:04:47 +0000
email notification upon new SC release
View Count: 790
[2016-03-14 03:51:41] |
User553714 - Posts: 184 |
Hi, From reading various threads I have realised that others are having the same issue as myself and waiting for SC version updates which have resulted from issues relating to a particular thread, mainly from a thread they initiated themselves. My suggestion is whether there is an easy way to add a feature where by someone can be notified of a new SC release which can be turned off/on? Maybe if the outcome of a support request will be the release of a new CS version the originator can be subscribed into a 1-off notification triggered by release of the next SC version? Maybe there could be a 2nd button added next to the "FOLLOW" button at the top of a Support Request thread to allow someone to subscribe into a notification triggered by release of the next SC version? This would hand the responsibility over to the user. Otherwise I will keep reloading the Software Update page and periodically check for version updates as I have been doing. Regards |
[2016-03-14 04:27:19] |
At least for the moment, there is a new version notice which has been put out to all users.
[2016-03-14 17:06:25] |
Marmany - Posts: 307 |
If these notices are to be sent out for each new version would it be possible to add a comment indicating the "importance" of the update? I run 5 platforms and prefer to update only when there is an issue that is of widespread importance or concerns an item of specific interest to myself. |
