Date/Time: Fri, 11 Sep 2026 12:26:16 +0000
s_SCPositionData::AveragePrice
View Count: 2247
[2016-03-14 03:03:43]
onnb - Posts: 666
1. the average price I see in ACSIL is dependent on the user settings in Chart Trade Settings->Position->Use Flat to Flat Average Price for Position Line?
2. the average price I see in ACSIL should be the same as the position line on the chart
[2016-03-14 04:33:49]
1. No it is not. It is a fill to fill calculation.
2. In the case of ACSIL we would use a separate variable for this.
Is this for simulated or non-simulated trading?
[2016-03-14 05:04:07]
onnb - Posts: 666
2. the average price I see in ACSIL should be the same as the position line on the chart?
forgot the question mark in my original post. it was a question, not a statement. for now just trying to get clarification how its supposed to work from ACSIL. from your answer, I understand that ACSIL would always return fill-fill average price?
this thread is related to simulated and non-simulated.
btw, the ACSIL docs here http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#s_SCPositionData
reference this page - http://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed
so it seems as if the acsil average price behaves according to the UI settings
[2016-03-14 16:17:21]
Yes, a fill to fill order grouping method is used.
The documentation has been updated.
This is true whether the trading is simulated or non-simulated.
However, there can be exceptions for non-simulated trading. For example, in the case of Interactive Brokers there is an option to always use the average price from the Interactive Brokers Position Data.
[2016-03-22 16:58:08]
onnb - Posts: 666
and with ACSIL, is lifo or fifo used?
[2016-03-22 17:52:25]
This is controllable:
Trade Activity Log: Order Fill Matching and Flat to Flat Definition
