Date/Time: Sun, 13 Sep 2026 20:37:37 +0000
Transact Connection
View Count: 1353
| [2016-03-14 01:57:37] |
| wingz - Posts: 121 |
I use Transact as my data provider. My charts keep stopping. I've closed and rebooted several times. Sierra hooks up to Transact and then stops updating. I talked to Transact tech support and they say there's not a problem that they know of. I keep getting a message that says Shockwave has quit working. I'm not sure if that's a Sierra issue or not but you guys may want to check on your end to see if there's a problem. This has happened several times since 6 PM EDT and I'm still not able to hold the connection. Transacts DOM is working perfectly.
| [2016-03-14 02:14:22] |
In reference to the previous message. .........when I disconnect Sierra and try to reconnect I'm getting a flash message that says Unknown Error code 60 version 1.3.5.0. Also........here is my message log in case you need to see it. Software version: 1379 | 2016-03-13 21:50:13 Uses New Spreadsheets | 2016-03-13 21:50:13 Usage end date: 2016-04-06 | 2016-03-13 21:50:13 Enabled for: Advanced Features. | 2016-03-13 21:50:13 Enabled for: Sierra Chart Historical Data Service. | 2016-03-13 21:50:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-13 21:50:13 Current selected Data/Trading service: TransAct Trading | 2016-03-13 21:50:13 Chart Update Interval: 900 | 2016-03-13 21:50:13 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-13 21:50:13 2016-03-13 21:50:17 Local computer time | 2016-03-13 21:50:13 2016-03-14 01:50:17 Local computer time in UTC | 2016-03-13 21:50:13 2016-03-13 21:50:17 Local computer time in SC Time Zone | 2016-03-13 21:50:13 2016-03-14 01:50:16 Server time in UTC | 2016-03-13 21:50:13 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-03-13 21:50:13 Program path: C:\SierraChart\ | 2016-03-13 21:50:13 Data Files path: C:\SierraChart\Data\ | 2016-03-13 21:50:13 OS Version Number: 6.1 | 2016-03-13 21:50:13 Locale Information: C | 2016-03-13 21:50:13 Checking for new symbol settings for ta | 2016-03-13 21:50:13 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-03-13 21:50:13 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-03-13 21:50:13 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-03-13 21:50:13 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-03-13 21:50:13 Symbol settings are up-to-date for ta | 2016-03-13 21:50:18 Files to Open on Start up | Opening file: Modern Family.cht | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: Daily Bars Chart Book.cht | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: Daily ES & YM Chartbook.cht | 2016-03-13 21:50:20 ES# [CB] Daily #12 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-03-13 21:50:20 ES# [CB] Daily #12 | There are no continuous futures contract symbols. Loading data normally. | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: Test Chartbook.cht | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: Test Chartbook 2.cht | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: YM Slow Sto Chartbook.cht | 2016-03-13 21:50:20 Files to Open on Start up | Opening file: ES Slow Sto Chartbook.cht | 2016-03-13 21:50:20 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-03-13 21:50:20 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-03-13 21:50:20 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-03-13 21:50:20 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-03-13 21:50:20 HD Request # 2 | Downloading Historical Daily chart data for $INX. Starting date: 2016-03-10. Service: sp.index | 2016-03-13 21:50:25 HD Request # 2 | Requesting historical Daily data for $INX starting at 2016-03-09 | 2016-03-13 21:50:25 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-03-13 21:50:25 Intraday data recording state for symbol ESz5 is set to download 'Pending'. | 2016-03-13 21:50:25 HD Request # 3 | Downloading Intraday chart data for ESz5 to the file ESz5.scid. Service: ta | 2016-03-13 21:50:25 HD Request # 3 | Download start Date-Time: 2015-12-18 09:43:52.000 | 2016-03-13 21:50:25 HD Request # 3 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:25 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:25 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol YMH6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol TFM6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol NQH6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol CLG6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol TFH6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol NQM6 is set to download 'Pending'. | 2016-03-13 21:50:25 HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-03-13 21:50:25 Socket (5) | Connected. | 2016-03-13 21:50:25 HD Request # 3 | Sending historical data logon request message. | 2016-03-13 21:50:25 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-03-13 21:50:25 Intraday data recording state for symbol YMM6 is set to download 'Pending'. | 2016-03-13 21:50:25 HD Request # 2 | Receiving historical Daily data for $INX starting at 2016-03-10 | 2016-03-13 21:50:25 HD Request # 2 | Writing historical Daily data to the file $INX.dly | 2016-03-13 21:50:25 HD Request # 2 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for $INX | 2016-03-13 21:50:25 HD Request # 2 | Daily download COMPLETE for $INX. Completion time: 0s. Unique request ID: 1 | 2016-03-13 21:50:25 Removed historical data download ID 1 | 2016-03-13 21:50:25 HD Request # 4 | Downloading Historical Daily chart data for IWM. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:25 HD Request # 4 | Requesting historical Daily data for IWM starting at 2016-03-09 | 2016-03-13 21:50:25 HD Request # 4 | Receiving historical Daily data for IWM starting at 2016-03-10 | 2016-03-13 21:50:25 HD Request # 4 | Writing historical Daily data to the file IWM.dly | 2016-03-13 21:50:25 HD Request # 4 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for IWM | 2016-03-13 21:50:25 HD Request # 4 | Daily download COMPLETE for IWM. Completion time: 0s. Unique request ID: 2 | 2016-03-13 21:50:25 Removed historical data download ID 2 | 2016-03-13 21:50:25 HD Request # 5 | Downloading Historical Daily chart data for XRT. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:25 HD Request # 5 | Requesting historical Daily data for XRT starting at 2016-03-09 | 2016-03-13 21:50:25 $INX Daily #8 | Reloading chart. | 2016-03-13 21:50:25 HD Request # 5 | Receiving historical Daily data for XRT starting at 2016-03-10 | 2016-03-13 21:50:25 HD Request # 5 | Writing historical Daily data to the file XRT.dly | 2016-03-13 21:50:25 HD Request # 5 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for XRT | 2016-03-13 21:50:25 HD Request # 5 | Daily download COMPLETE for XRT. Completion time: 0s. Unique request ID: 3 | 2016-03-13 21:50:25 Removed historical data download ID 3 | 2016-03-13 21:50:25 HD Request # 6 | Downloading Historical Daily chart data for IYT. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:25 HD Request # 6 | Requesting historical Daily data for IYT starting at 2016-03-09 | 2016-03-13 21:50:25 HD Request # 6 | Receiving historical Daily data for IYT starting at 2016-03-10 | 2016-03-13 21:50:25 HD Request # 6 | Writing historical Daily data to the file IYT.dly | 2016-03-13 21:50:25 HD Request # 6 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for IYT | 2016-03-13 21:50:25 HD Request # 6 | Daily download COMPLETE for IYT. Completion time: 0s. Unique request ID: 4 | 2016-03-13 21:50:25 Removed historical data download ID 4 | 2016-03-13 21:50:25 HD Request # 7 | Downloading Historical Daily chart data for SMH. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:25 HD Request # 7 | Requesting historical Daily data for SMH starting at 2016-03-09 | 2016-03-13 21:50:25 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-12-18 09:43:52. Record interval: 2. Symbol: ESz5 | 2016-03-13 21:50:25 Socket (5) | Shutdown and closed. | 2016-03-13 21:50:25 The network socket for historical data has been closed. | 2016-03-13 21:50:25 HD Request # 3 | Historical data for ESz5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:25 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESz5 | 2016-03-13 21:50:25 HD Request # 3 | Intraday download COMPLETE for ESz5. Completion time: 0s. Unique request ID: 9 | 2016-03-13 21:50:25 Removed historical data download ID 9 | 2016-03-13 21:50:25 HD Request # 8 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-03-13 21:50:25 HD Request # 8 | Download start Date-Time: 2016-03-13 21:44:06.000 | 2016-03-13 21:50:25 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:25 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:25 Socket (6) | Connected. | 2016-03-13 21:50:25 HD Request # 8 | Sending historical data logon request message. | 2016-03-13 21:50:25 $INX Daily #65 | Reloading chart. | 2016-03-13 21:50:25 HD Request # 7 | Receiving historical Daily data for SMH starting at 2016-03-10 | 2016-03-13 21:50:25 HD Request # 7 | Writing historical Daily data to the file SMH.dly | 2016-03-13 21:50:25 HD Request # 7 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for SMH | 2016-03-13 21:50:25 HD Request # 7 | Daily download COMPLETE for SMH. Completion time: 0s. Unique request ID: 5 | 2016-03-13 21:50:25 Removed historical data download ID 5 | 2016-03-13 21:50:25 HD Request # 9 | Downloading Historical Daily chart data for KRE. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:25 HD Request # 9 | Requesting historical Daily data for KRE starting at 2016-03-09 | 2016-03-13 21:50:25 IWM Daily #1 | Reloading chart. | 2016-03-13 21:50:25 XRT Daily #3 | Reloading chart. | 2016-03-13 21:50:25 $INX Daily #5 | Reloading chart. | 2016-03-13 21:50:25 IYT Daily #4 | Reloading chart. | 2016-03-13 21:50:25 SMH Daily #5 | Reloading chart. | 2016-03-13 21:50:26 HD Request # 9 | Receiving historical Daily data for KRE starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 9 | Writing historical Daily data to the file KRE.dly | 2016-03-13 21:50:26 HD Request # 9 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for KRE | 2016-03-13 21:50:26 HD Request # 9 | Daily download COMPLETE for KRE. Completion time: 0s. Unique request ID: 6 | 2016-03-13 21:50:26 Removed historical data download ID 6 | 2016-03-13 21:50:26 HD Request # 10 | Downloading Historical Daily chart data for IBB. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:26 HD Request # 10 | Requesting historical Daily data for IBB starting at 2016-03-09 | 2016-03-13 21:50:26 KRE Daily #6 | Reloading chart. | 2016-03-13 21:50:26 HD Request # 10 | Receiving historical Daily data for IBB starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 10 | Writing historical Daily data to the file IBB.dly | 2016-03-13 21:50:26 HD Request # 10 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for IBB | 2016-03-13 21:50:26 HD Request # 10 | Daily download COMPLETE for IBB. Completion time: 1s. Unique request ID: 7 | 2016-03-13 21:50:26 Removed historical data download ID 7 | 2016-03-13 21:50:26 HD Request # 11 | Downloading Historical Daily chart data for ESH6. Starting date: 2016-03-11. Service: ta | 2016-03-13 21:50:26 HD Request # 11 | Requesting historical Daily data for ESH16 starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:06. Record interval: 2. Symbol: ESH6 | 2016-03-13 21:50:26 HD Request # 11 | Receiving historical Daily data for ESH6 starting at 2016-03-11 | 2016-03-13 21:50:26 HD Request # 11 | Writing historical Daily data to the file ESH6.dly | 2016-03-13 21:50:26 HD Request # 11 | Received 3 records from 2016-03-11 00:00:00 to 2016-03-14 00:00:00 (4.0 days) and wrote 2 records for ESH6 | 2016-03-13 21:50:26 HD Request # 11 | Daily download COMPLETE for ESH6. Completion time: 0s. Unique request ID: 8 | 2016-03-13 21:50:26 Removed historical data download ID 8 | 2016-03-13 21:50:26 HD Request # 12 | Downloading Historical Daily chart data for EXR. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:26 HD Request # 12 | Requesting historical Daily data for EXR starting at 2016-03-09 | 2016-03-13 21:50:26 Socket (6) | Shutdown and closed. | 2016-03-13 21:50:26 HD Request # 8 | Historical data for ESH6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:26 The network socket for historical data has been closed. | 2016-03-13 21:50:26 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-03-13 21:50:26 HD Request # 8 | Intraday download COMPLETE for ESH6. Completion time: 1s. Unique request ID: 17 | 2016-03-13 21:50:26 Removed historical data download ID 17 | 2016-03-13 21:50:26 HD Request # 13 | Downloading Intraday chart data for YMH6 to the file YMH6.scid. Service: ta | 2016-03-13 21:50:26 HD Request # 13 | Download start Date-Time: 2016-03-13 21:43:33.000 | 2016-03-13 21:50:26 HD Request # 13 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:26 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:26 Socket (7) | Connected. | 2016-03-13 21:50:26 HD Request # 13 | Sending historical data logon request message. | 2016-03-13 21:50:26 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:43:33. Record interval: 2. Symbol: YMH6 | 2016-03-13 21:50:26 HD Request # 12 | Receiving historical Daily data for EXR starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 12 | Writing historical Daily data to the file EXR.dly | 2016-03-13 21:50:26 HD Request # 12 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for EXR | 2016-03-13 21:50:26 HD Request # 12 | Daily download COMPLETE for EXR. Completion time: 0s. Unique request ID: 10 | 2016-03-13 21:50:26 Removed historical data download ID 10 | 2016-03-13 21:50:26 HD Request # 14 | Downloading Historical Daily chart data for CHKP. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:26 HD Request # 14 | Requesting historical Daily data for CHKP starting at 2016-03-09 | 2016-03-13 21:50:26 HD Request # 13 | Historical data for YMH6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:26 Socket (7) | Shutdown and closed. | 2016-03-13 21:50:26 The network socket for historical data has been closed. | 2016-03-13 21:50:26 HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH6 | 2016-03-13 21:50:26 HD Request # 13 | Intraday download COMPLETE for YMH6. Completion time: 0s. Unique request ID: 19 | 2016-03-13 21:50:26 Removed historical data download ID 19 | 2016-03-13 21:50:26 HD Request # 15 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-03-13 21:50:26 HD Request # 15 | Download start Date-Time: 2016-03-11 16:05:00.000 | 2016-03-13 21:50:26 HD Request # 15 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:26 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:26 Socket (8) | Connected. | 2016-03-13 21:50:26 HD Request # 15 | Sending historical data logon request message. | 2016-03-13 21:50:26 HD Request # 14 | Receiving historical Daily data for CHKP starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 14 | Writing historical Daily data to the file CHKP.dly | 2016-03-13 21:50:26 HD Request # 14 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for CHKP | 2016-03-13 21:50:26 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2016-03-11 16:05:00. Record interval: 2. Symbol: TICK-NYSE | 2016-03-13 21:50:26 HD Request # 14 | Daily download COMPLETE for CHKP. Completion time: 0s. Unique request ID: 11 | 2016-03-13 21:50:26 Removed historical data download ID 11 | 2016-03-13 21:50:26 HD Request # 16 | Downloading Historical Daily chart data for FDX. Starting date: 2016-03-10. Service: equities.us | 2016-03-13 21:50:26 HD Request # 16 | Requesting historical Daily data for FDX starting at 2016-03-09 | 2016-03-13 21:50:26 HD Request # 15 | Decompressing data. | 2016-03-13 21:50:26 HD Request # 15 | Receiving Intraday data for TICK-NYSE starting at 2016-03-11 16:05:00 | 2016-03-13 21:50:26 HD Request # 15 | Timestamp of first Intraday data file record written: 2016-03-11 16:05:00 | 2016-03-13 21:50:26 HD Request # 15 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:26 Socket (8) | Shutdown and closed. | 2016-03-13 21:50:26 The network socket for historical data has been closed. | 2016-03-13 21:50:26 HD Request # 15 | Received 1 record from 2016-03-11 16:05:00 to 2016-03-11 16:05:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2016-03-13 21:50:26 HD Request # 15 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 20 | 2016-03-13 21:50:26 Removed historical data download ID 20 | 2016-03-13 21:50:26 HD Request # 17 | Downloading Intraday chart data for TFM6 to the file TFM6.scid. Service: ta | 2016-03-13 21:50:26 HD Request # 17 | Download start Date-Time: 2016-03-13 21:38:46.000 | 2016-03-13 21:50:26 HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:26 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:26 Socket (9) | Connected. | 2016-03-13 21:50:26 HD Request # 17 | Sending historical data logon request message. | 2016-03-13 21:50:26 HD Request # 16 | Receiving historical Daily data for FDX starting at 2016-03-10 | 2016-03-13 21:50:26 HD Request # 16 | Writing historical Daily data to the file FDX.dly | 2016-03-13 21:50:26 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:38:46. Record interval: 2. Symbol: TFM6 | 2016-03-13 21:50:26 HD Request # 16 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for FDX | 2016-03-13 21:50:26 HD Request # 16 | Daily download COMPLETE for FDX. Completion time: 0s. Unique request ID: 12 | 2016-03-13 21:50:26 Removed historical data download ID 12 | 2016-03-13 21:50:26 HD Request # 18 | Downloading Historical Daily chart data for $INDU. Starting date: 2016-03-10. Service: ta | 2016-03-13 21:50:26 HD Request # 18 | Requesting historical Daily data for $INDU starting at 2016-03-09 | 2016-03-13 21:50:26 IBB Daily #15 | Reloading chart. | 2016-03-13 21:50:26 Socket (9) | Shutdown and closed. | 2016-03-13 21:50:26 The network socket for historical data has been closed. | 2016-03-13 21:50:26 HD Request # 17 | Historical data for TFM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:26 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFM6 | 2016-03-13 21:50:26 HD Request # 17 | Intraday download COMPLETE for TFM6. Completion time: 0s. Unique request ID: 21 | 2016-03-13 21:50:26 Removed historical data download ID 21 | 2016-03-13 21:50:26 HD Request # 19 | Downloading Intraday chart data for NQH6 to the file NQH6.scid. Service: ta | 2016-03-13 21:50:26 HD Request # 19 | Download start Date-Time: 2016-03-13 21:44:14.000 | 2016-03-13 21:50:26 HD Request # 19 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:26 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:27 Socket (10) | Connected. | 2016-03-13 21:50:27 HD Request # 19 | Sending historical data logon request message. | 2016-03-13 21:50:27 ESH6 Daily #1 | Reloading chart. | 2016-03-13 21:50:27 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:14. Record interval: 2. Symbol: NQH6 | 2016-03-13 21:50:27 HD Request # 18 | Receiving historical Daily data for $INDU starting at 2016-03-10 | 2016-03-13 21:50:27 HD Request # 18 | Writing historical Daily data to the file $INDU.dly | 2016-03-13 21:50:27 HD Request # 18 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for $INDU | 2016-03-13 21:50:27 HD Request # 18 | Daily download COMPLETE for $INDU. Completion time: 1s. Unique request ID: 13 | 2016-03-13 21:50:27 Removed historical data download ID 13 | 2016-03-13 21:50:27 HD Request # 20 | Downloading Historical Daily chart data for $NYA. Starting date: 2016-03-10. Service: nyse.index | 2016-03-13 21:50:27 Socket (10) | Shutdown and closed. | 2016-03-13 21:50:27 The network socket for historical data has been closed. | 2016-03-13 21:50:27 HD Request # 20 | Requesting historical Daily data for $NYA starting at 2016-03-09 | 2016-03-13 21:50:27 HD Request # 19 | Historical data for NQH6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:27 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH6 | 2016-03-13 21:50:27 HD Request # 19 | Intraday download COMPLETE for NQH6. Completion time: 1s. Unique request ID: 22 | 2016-03-13 21:50:27 Removed historical data download ID 22 | 2016-03-13 21:50:27 HD Request # 21 | Downloading Intraday chart data for CLG6 to the file CLG6.scid. Service: ta | 2016-03-13 21:50:27 HD Request # 21 | Download start Date-Time: 2016-01-20 14:29:49.000 | 2016-03-13 21:50:27 HD Request # 21 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:27 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:27 EXR Daily #3 | Reloading chart. | 2016-03-13 21:50:27 CHKP Daily #4 | Reloading chart. | 2016-03-13 21:50:27 Socket (11) | Connected. | 2016-03-13 21:50:27 HD Request # 21 | Sending historical data logon request message. | 2016-03-13 21:50:27 FDX Daily #5 | Reloading chart. | 2016-03-13 21:50:27 $INDU Daily #6 | Reloading chart. | 2016-03-13 21:50:27 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-01-20 14:29:49. Record interval: 2. Symbol: CLG6 | 2016-03-13 21:50:27 HD Request # 20 | Receiving historical Daily data for $NYA starting at 2016-03-10 | 2016-03-13 21:50:27 HD Request # 20 | Writing historical Daily data to the file $NYA.dly | 2016-03-13 21:50:27 Socket (11) | Shutdown and closed. | 2016-03-13 21:50:27 The network socket for historical data has been closed. | 2016-03-13 21:50:27 HD Request # 20 | Received 3 records from 2016-03-10 00:00:00 to 2016-03-11 00:00:00 (2.0 days) and wrote 2 records for $NYA | 2016-03-13 21:50:27 HD Request # 20 | Daily download COMPLETE for $NYA. Completion time: 0s. Unique request ID: 14 | 2016-03-13 21:50:27 Removed historical data download ID 14 | 2016-03-13 21:50:27 HD Request # 21 | Historical data for CLG6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:27 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLG6 | 2016-03-13 21:50:27 HD Request # 21 | Intraday download COMPLETE for CLG6. Completion time: 0s. Unique request ID: 23 | 2016-03-13 21:50:27 Removed historical data download ID 23 | 2016-03-13 21:50:27 HD Request # 22 | Downloading Historical Daily chart data for YM#. Starting date: 2016-03-11. Service: ta | 2016-03-13 21:50:27 HD Request # 22 | Requesting historical Daily Continuous data for YMZ10 starting at 2016-03-10 | 2016-03-13 21:50:27 HD Request # 23 | Downloading Intraday chart data for TFH6 to the file TFH6.scid. Service: ta | 2016-03-13 21:50:27 HD Request # 23 | Download start Date-Time: 2016-03-13 21:41:41.000 | 2016-03-13 21:50:27 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:27 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:27 EXR Weekly #7 | Reloading chart. | 2016-03-13 21:50:27 $NYA Daily #1 | Reloading chart. | 2016-03-13 21:50:27 Socket (12) | Connected. | 2016-03-13 21:50:27 HD Request # 23 | Sending historical data logon request message. | 2016-03-13 21:50:27 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:41:41. Record interval: 2. Symbol: TFH6 | 2016-03-13 21:50:27 $INDU Weekly #4 | Reloading chart. | 2016-03-13 21:50:27 Socket (12) | Shutdown and closed. | 2016-03-13 21:50:27 The network socket for historical data has been closed. | 2016-03-13 21:50:27 HD Request # 22 | Receiving historical Daily data for YM# starting at 2016-03-11 | 2016-03-13 21:50:27 HD Request # 22 | Writing historical Daily data to the file YM#.dly | 2016-03-13 21:50:27 HD Request # 22 | Received 3 records from 2016-03-11 00:00:00 to 2016-03-14 00:00:00 (4.0 days) and wrote 2 records for YM# | 2016-03-13 21:50:27 HD Request # 22 | Daily download COMPLETE for YM#. Completion time: 0s. Unique request ID: 15 | 2016-03-13 21:50:27 Removed historical data download ID 15 | 2016-03-13 21:50:27 HD Request # 23 | Historical data for TFH6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:27 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFH6 | 2016-03-13 21:50:27 HD Request # 23 | Intraday download COMPLETE for TFH6. Completion time: 0s. Unique request ID: 24 | 2016-03-13 21:50:27 Removed historical data download ID 24 | 2016-03-13 21:50:27 HD Request # 24 | Downloading Historical Daily chart data for NQ#. Starting date: 2016-03-11. Service: ta | 2016-03-13 21:50:27 HD Request # 24 | Requesting historical Daily Continuous data for NQZ10 starting at 2016-03-10 | 2016-03-13 21:50:27 HD Request # 25 | Downloading Intraday chart data for NQM6 to the file NQM6.scid. Service: ta | 2016-03-13 21:50:27 HD Request # 25 | Download start Date-Time: 2016-03-13 21:40:02.000 | 2016-03-13 21:50:27 HD Request # 25 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:27 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:27 Socket (13) | Connected. | 2016-03-13 21:50:27 HD Request # 25 | Sending historical data logon request message. | 2016-03-13 21:50:27 $INDU Weekly #6 | Reloading chart. | 2016-03-13 21:50:27 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:40:02. Record interval: 2. Symbol: NQM6 | 2016-03-13 21:50:27 HD Request # 24 | Receiving historical Daily data for NQ# starting at 2016-03-11 | 2016-03-13 21:50:27 HD Request # 24 | Writing historical Daily data to the file NQ#.dly | 2016-03-13 21:50:27 Socket (13) | Shutdown and closed. | 2016-03-13 21:50:27 The network socket for historical data has been closed. | 2016-03-13 21:50:27 HD Request # 24 | Received 3 records from 2016-03-11 00:00:00 to 2016-03-14 00:00:00 (4.0 days) and wrote 2 records for NQ# | 2016-03-13 21:50:27 HD Request # 24 | Daily download COMPLETE for NQ#. Completion time: 0s. Unique request ID: 16 | 2016-03-13 21:50:27 Removed historical data download ID 16 | 2016-03-13 21:50:27 HD Request # 25 | Historical data for NQM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:27 HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM6 | 2016-03-13 21:50:27 HD Request # 25 | Intraday download COMPLETE for NQM6. Completion time: 0s. Unique request ID: 25 | 2016-03-13 21:50:27 Removed historical data download ID 25 | 2016-03-13 21:50:27 HD Request # 26 | Downloading Historical Daily chart data for ES#. Starting date: 2016-03-11. Service: ta | 2016-03-13 21:50:27 HD Request # 26 | Requesting historical Daily Continuous data for ESZ10 starting at 2016-03-10 | 2016-03-13 21:50:27 HD Request # 27 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-03-13 21:50:27 HD Request # 27 | Download start Date-Time: 2016-03-13 21:44:07.000 | 2016-03-13 21:50:27 HD Request # 27 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:27 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:27 Socket (14) | Connected. | 2016-03-13 21:50:28 HD Request # 27 | Sending historical data logon request message. | 2016-03-13 21:50:28 NQ# Weekly #9 | Reloading chart. | 2016-03-13 21:50:28 $INDU Daily #10 | Reloading chart. | 2016-03-13 21:50:28 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:07. Record interval: 2. Symbol: ESM6 | 2016-03-13 21:50:28 HD Request # 26 | Receiving historical Daily data for ES# starting at 2016-03-11 | 2016-03-13 21:50:28 HD Request # 26 | Writing historical Daily data to the file ES#.dly | 2016-03-13 21:50:28 HD Request # 26 | Received 3 records from 2016-03-11 00:00:00 to 2016-03-14 00:00:00 (4.0 days) and wrote 2 records for ES# | 2016-03-13 21:50:28 Socket (14) | Shutdown and closed. | 2016-03-13 21:50:28 The network socket for historical data has been closed. | 2016-03-13 21:50:28 HD Request # 26 | Daily download COMPLETE for ES#. Completion time: 0s. Unique request ID: 18 | 2016-03-13 21:50:28 Removed historical data download ID 18 | 2016-03-13 21:50:28 HD Request # 27 | Historical data for ESM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:28 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-03-13 21:50:28 HD Request # 27 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 26 | 2016-03-13 21:50:28 Removed historical data download ID 26 | 2016-03-13 21:50:28 HD Request # 28 | Downloading Intraday chart data for YMM6 to the file YMM6.scid. Service: ta | 2016-03-13 21:50:28 HD Request # 28 | Download start Date-Time: 2016-03-13 21:42:09.000 | 2016-03-13 21:50:28 HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:28 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:28 ES# [CB] Daily #12 | Reloading chart. | 2016-03-13 21:50:28 ES# [CB] Daily #12 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-03-13 21:50:28 ES# [CB] Daily #12 | There are no continuous futures contract symbols. Loading data normally. | 2016-03-13 21:50:28 Socket (15) | Connected. | 2016-03-13 21:50:28 HD Request # 28 | Sending historical data logon request message. | 2016-03-13 21:50:28 YM# Monthly #13 | Reloading chart. | 2016-03-13 21:50:28 HD Request # 28 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:42:09. Record interval: 2. Symbol: YMM6 | 2016-03-13 21:50:28 Socket (15) | Shutdown and closed. | 2016-03-13 21:50:28 The network socket for historical data has been closed. | 2016-03-13 21:50:28 HD Request # 28 | Historical data for YMM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-03-13 21:50:28 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM6 | 2016-03-13 21:50:28 HD Request # 28 | Intraday download COMPLETE for YMM6. Completion time: 0s. Unique request ID: 27 | 2016-03-13 21:50:28 Removed historical data download ID 27 | 2016-03-13 21:50:28 YM# Weekly #2 | Reloading chart. | 2016-03-13 21:50:28 NQ# Daily #7 | Reloading chart. | 2016-03-13 21:50:28 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 21:50:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:50:38 Socket (16) | Connected. | 2016-03-13 21:50:38 TransAct Trading | Connected to server. | 2016-03-13 21:50:38 TransAct Trading | Sending logon request message. | 2016-03-13 21:50:38 TransAct Trading | Received logon response. | 2016-03-13 21:50:40 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 21:50:40 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 21:50:40 TransAct Trading | Successfully connected. Operation Successful. | 2016-03-13 21:50:40 TransAct Trading | Connected to data and trading server. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: CLN5. ID: 1 | 2016-03-13 21:50:40 Intraday data recording state for symbol CLN5 is set to download 'Pending'. | 2016-03-13 21:50:40 Delaying start of download for CLN5 | 2016-03-13 21:50:40 Symbol Error - CLN5 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 2 | 2016-03-13 21:50:40 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 443 | 2016-03-13 21:50:40 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-03-13 21:50:40 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:40 HD Request # 29 | Downloading Intraday chart data for CLN5 to the file CLN5.scid. Service: ta | 2016-03-13 21:50:40 HD Request # 29 | Download start Date-Time: 2015-06-22 14:29:54.000 | 2016-03-13 21:50:40 HD Request # 29 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-03-13 21:50:40 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:40 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-03-13 21:50:40 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 4 | 2016-03-13 21:50:40 Intraday data recording state for symbol TFM6 is set to download 'Pending'. | 2016-03-13 21:50:40 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: $NYA. ID: 5 | 2016-03-13 21:50:40 Symbol Error - $NYA is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: YMM6. ID: 6 | 2016-03-13 21:50:40 Intraday data recording state for symbol YMM6 is set to download 'Pending'. | 2016-03-13 21:50:40 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: NQH6. ID: 7 | 2016-03-13 21:50:40 Intraday data recording state for symbol NQH6 is set to download 'Pending'. | 2016-03-13 21:50:40 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:40 Socket (17) | Connected. | 2016-03-13 21:50:40 SC DTC Data | Connected to server. | 2016-03-13 21:50:40 SC DTC Data | Sending Encoding Request to server | 2016-03-13 21:50:40 Socket (18) | Connected. | 2016-03-13 21:50:40 HD Request # 29 | Sending historical data logon request message. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: YM#. ID: 8 | 2016-03-13 21:50:40 Not starting updates for a symbol containing a #: YM# | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: $INX. ID: 9 | 2016-03-13 21:50:40 Symbol Error - $INX is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: CLG6. ID: 10 | 2016-03-13 21:50:40 Intraday data recording state for symbol CLG6 is set to download 'Pending'. | 2016-03-13 21:50:40 Symbol Error - CLG6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: TFH6. ID: 11 | 2016-03-13 21:50:40 Intraday data recording state for symbol TFH6 is set to download 'Pending'. | 2016-03-13 21:50:40 Symbol Error - TFH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: YMH6. ID: 12 | 2016-03-13 21:50:40 Intraday data recording state for symbol YMH6 is set to download 'Pending'. | 2016-03-13 21:50:40 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:40 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-03-13 21:50:40 SC DTC Data | Sending logon request message. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: $INDU. ID: 13 | 2016-03-13 21:50:40 Symbol Error - $INDU is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 HD Request # 29 | Requesting Intraday data. Start Date-Time: 2015-06-22 14:29:54. Record interval: 2. Symbol: CLN5 | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: IWM. ID: 14 | 2016-03-13 21:50:40 Symbol Error - IWM is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: XRT. ID: 15 | 2016-03-13 21:50:40 Symbol Error - XRT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 16 | 2016-03-13 21:50:40 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-03-13 21:50:40 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: IYT. ID: 17 | 2016-03-13 21:50:40 Symbol Error - IYT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: SMH. ID: 18 | 2016-03-13 21:50:40 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: KRE. ID: 19 | 2016-03-13 21:50:40 Symbol Error - KRE is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: NQ#. ID: 20 | 2016-03-13 21:50:40 Not starting updates for a symbol containing a #: NQ# | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: IBB. ID: 21 | 2016-03-13 21:50:40 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: ESz5. ID: 22 | 2016-03-13 21:50:40 Intraday data recording state for symbol ESz5 is set to download 'Pending'. | 2016-03-13 21:50:40 Symbol Error - ESz5 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:40 TransAct Trading | Starting real-time market data updates for: EXR. ID: 23 | 2016-03-13 21:50:41 Symbol Error - EXR is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:41 TransAct Trading | Starting real-time market data updates for: CHKP. ID: 24 | 2016-03-13 21:50:41 Symbol Error - CHKP is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:41 HD Request # 29 | Decompressing data. | 2016-03-13 21:50:41 HD Request # 29 | Receiving Intraday data for CLN5 starting at 2015-06-22 14:29:54 | 2016-03-13 21:50:41 HD Request # 29 | Timestamp of first Intraday data file record written: 2015-06-22 14:29:54 | 2016-03-13 21:50:41 Socket (18) | Shutdown and closed. | 2016-03-13 21:50:41 The network socket for historical data has been closed. | 2016-03-13 21:50:41 HD Request # 29 | Received 1 record from 2015-06-22 14:29:54 to 2015-06-22 14:29:54 (0.0 seconds) and wrote 1 record for CLN5 | 2016-03-13 21:50:41 HD Request # 29 | Intraday download COMPLETE for CLN5. Completion time: 1s. Unique request ID: 28 | 2016-03-13 21:50:41 Removed historical data download ID 28 | 2016-03-13 21:50:41 Real-time Intraday chart data file updates started for CLN5 | 2016-03-13 21:50:41 Opened cached Intraday file: C:\SierraChart\Data\CLN5.scid | 2016-03-13 21:50:41 Intraday chart data file opened for CLN5 | 2016-03-13 21:50:41 Delaying start of download for TICK-NYSE | 2016-03-13 21:50:41 TransAct Trading | Starting real-time market data updates for: ES#. ID: 25 | 2016-03-13 21:50:41 Not starting updates for a symbol containing a #: ES# | 2016-03-13 21:50:41 TransAct Trading | Starting real-time market data updates for: NQM6. ID: 26 | 2016-03-13 21:50:41 Intraday data recording state for symbol NQM6 is set to download 'Pending'. | 2016-03-13 21:50:41 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 21:50:41 TransAct Trading | Starting real-time market data updates for: FDX. ID: 27 | 2016-03-13 21:50:41 Symbol Error - FDX is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 21:50:41 SC DTC Data | Received logon response. | 2016-03-13 21:50:41 SC DTC Data | Server Name: SC Real-Time Server. | 2016-03-13 21:50:41 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-03-13 21:50:41 SC DTC Data | Successfully connected. | 2016-03-13 21:50:41 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-03-13 21:50:41 Delaying start of download for TICK-NYSE | 2016-03-13 21:50:42 HD Request # 30 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-03-13 21:50:45 HD Request # 30 | Download start Date-Time: 2016-03-11 16:05:00.000 | 2016-03-13 21:50:45 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:45 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:45 Socket (19) | Connected. | 2016-03-13 21:50:45 HD Request # 30 | Sending historical data logon request message. | 2016-03-13 21:50:45 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2016-03-11 16:05:00. Record interval: 2. Symbol: TICK-NYSE | 2016-03-13 21:50:45 HD Request # 30 | Decompressing data. | 2016-03-13 21:50:45 HD Request # 30 | Receiving Intraday data for TICK-NYSE starting at 2016-03-11 16:05:00 | 2016-03-13 21:50:45 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-03-11 16:05:00 | 2016-03-13 21:50:45 Socket (19) | Shutdown and closed. | 2016-03-13 21:50:45 The network socket for historical data has been closed. | 2016-03-13 21:50:45 HD Request # 30 | Received 1 record from 2016-03-11 16:05:00 to 2016-03-11 16:05:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2016-03-13 21:50:45 HD Request # 30 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 29 | 2016-03-13 21:50:45 Removed historical data download ID 29 | 2016-03-13 21:50:45 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-03-13 21:50:45 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2016-03-13 21:50:45 Intraday chart data file opened for TICK-NYSE | 2016-03-13 21:50:45 HD Request # 31 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-03-13 21:50:45 HD Request # 31 | Download start Date-Time: 2016-03-13 21:44:07.000 | 2016-03-13 21:50:45 HD Request # 31 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:45 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:45 Socket (20) | Connected. | 2016-03-13 21:50:45 HD Request # 31 | Sending historical data logon request message. | 2016-03-13 21:50:45 HD Request # 31 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:07. Record interval: 2. Symbol: ESM6 | 2016-03-13 21:50:45 HD Request # 31 | Decompressing data. | 2016-03-13 21:50:45 HD Request # 31 | Receiving Intraday data for ESM6 starting at 2016-03-13 21:44:07 | 2016-03-13 21:50:45 HD Request # 31 | Timestamp of first Intraday data file record written: 2016-03-13 21:44:07 | 2016-03-13 21:50:45 Socket (20) | Shutdown and closed. | 2016-03-13 21:50:45 The network socket for historical data has been closed. | 2016-03-13 21:50:45 HD Request # 31 | Received 52 records from 2016-03-13 21:44:07 to 2016-03-13 21:49:30 (5.4 minutes) and wrote 52 records for ESM6 | 2016-03-13 21:50:45 HD Request # 31 | Intraday download COMPLETE for ESM6. Completion time: 1s. Unique request ID: 30 | 2016-03-13 21:50:45 Removed historical data download ID 30 | 2016-03-13 21:50:45 Real-time Intraday chart data file updates started for ESM6 | 2016-03-13 21:50:45 Opened cached Intraday file: C:\SierraChart\Data\ESM6.scid | 2016-03-13 21:50:45 Intraday chart data file opened for ESM6 | 2016-03-13 21:50:45 HD Request # 32 | Downloading Intraday chart data for TFM6 to the file TFM6.scid. Service: ta | 2016-03-13 21:50:45 HD Request # 32 | Download start Date-Time: 2016-03-13 21:38:46.000 | 2016-03-13 21:50:45 HD Request # 32 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:45 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:45 Socket (21) | Connected. | 2016-03-13 21:50:45 HD Request # 32 | Sending historical data logon request message. | 2016-03-13 21:50:45 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:38:46. Record interval: 2. Symbol: TFM6 | 2016-03-13 21:50:45 HD Request # 32 | Decompressing data. | 2016-03-13 21:50:45 HD Request # 32 | Receiving Intraday data for TFM6 starting at 2016-03-13 21:38:46 | 2016-03-13 21:50:45 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-03-13 21:38:46 | 2016-03-13 21:50:45 Socket (21) | Shutdown and closed. | 2016-03-13 21:50:45 The network socket for historical data has been closed. | 2016-03-13 21:50:45 HD Request # 32 | Received 8 records from 2016-03-13 21:38:46 to 2016-03-13 21:42:04 (3.3 minutes) and wrote 8 records for TFM6 | 2016-03-13 21:50:45 HD Request # 32 | Intraday download COMPLETE for TFM6. Completion time: 0s. Unique request ID: 31 | 2016-03-13 21:50:45 Removed historical data download ID 31 | 2016-03-13 21:50:45 Real-time Intraday chart data file updates started for TFM6 | 2016-03-13 21:50:45 Opened cached Intraday file: C:\SierraChart\Data\TFM6.scid | 2016-03-13 21:50:45 Intraday chart data file opened for TFM6 | 2016-03-13 21:50:45 HD Request # 33 | Downloading Intraday chart data for YMM6 to the file YMM6.scid. Service: ta | 2016-03-13 21:50:45 HD Request # 33 | Download start Date-Time: 2016-03-13 21:42:09.000 | 2016-03-13 21:50:45 HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:45 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:45 Socket (22) | Connected. | 2016-03-13 21:50:45 HD Request # 33 | Sending historical data logon request message. | 2016-03-13 21:50:45 HD Request # 33 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:42:09. Record interval: 2. Symbol: YMM6 | 2016-03-13 21:50:45 HD Request # 33 | Decompressing data. | 2016-03-13 21:50:46 HD Request # 33 | Receiving Intraday data for YMM6 starting at 2016-03-13 21:42:09 | 2016-03-13 21:50:46 HD Request # 33 | Timestamp of first Intraday data file record written: 2016-03-13 21:42:09 | 2016-03-13 21:50:46 Socket (22) | Shutdown and closed. | 2016-03-13 21:50:46 The network socket for historical data has been closed. | 2016-03-13 21:50:46 HD Request # 33 | Received 25 records from 2016-03-13 21:42:09 to 2016-03-13 21:50:34 (8.4 minutes) and wrote 25 records for YMM6 | 2016-03-13 21:50:46 HD Request # 33 | Intraday download COMPLETE for YMM6. Completion time: 0s. Unique request ID: 32 | 2016-03-13 21:50:46 Removed historical data download ID 32 | 2016-03-13 21:50:46 Real-time Intraday chart data file updates started for YMM6 | 2016-03-13 21:50:46 Opened cached Intraday file: C:\SierraChart\Data\YMM6.scid | 2016-03-13 21:50:46 Intraday chart data file opened for YMM6 | 2016-03-13 21:50:46 HD Request # 34 | Downloading Intraday chart data for NQH6 to the file NQH6.scid. Service: ta | 2016-03-13 21:50:46 HD Request # 34 | Download start Date-Time: 2016-03-13 21:44:14.000 | 2016-03-13 21:50:46 HD Request # 34 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:46 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:46 Socket (23) | Connected. | 2016-03-13 21:50:46 HD Request # 34 | Sending historical data logon request message. | 2016-03-13 21:50:46 HD Request # 34 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:14. Record interval: 2. Symbol: NQH6 | 2016-03-13 21:50:46 HD Request # 34 | Decompressing data. | 2016-03-13 21:50:46 HD Request # 34 | Receiving Intraday data for NQH6 starting at 2016-03-13 21:44:14 | 2016-03-13 21:50:46 HD Request # 34 | Timestamp of first Intraday data file record written: 2016-03-13 21:44:14 | 2016-03-13 21:50:46 Socket (23) | Shutdown and closed. | 2016-03-13 21:50:46 The network socket for historical data has been closed. | 2016-03-13 21:50:46 HD Request # 34 | Received 9 records from 2016-03-13 21:44:14 to 2016-03-13 21:48:06 (3.9 minutes) and wrote 9 records for NQH6 | 2016-03-13 21:50:46 HD Request # 34 | Intraday download COMPLETE for NQH6. Completion time: 0s. Unique request ID: 33 | 2016-03-13 21:50:46 Removed historical data download ID 33 | 2016-03-13 21:50:46 Real-time Intraday chart data file updates started for NQH6 | 2016-03-13 21:50:46 Opened cached Intraday file: C:\SierraChart\Data\NQH6.scid | 2016-03-13 21:50:46 Intraday chart data file opened for NQH6 | 2016-03-13 21:50:46 HD Request # 35 | Downloading Intraday chart data for CLG6 to the file CLG6.scid. Service: ta | 2016-03-13 21:50:46 HD Request # 35 | Download start Date-Time: 2016-01-20 14:29:49.000 | 2016-03-13 21:50:46 HD Request # 35 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:46 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:46 Socket (24) | Connected. | 2016-03-13 21:50:46 HD Request # 35 | Sending historical data logon request message. | 2016-03-13 21:50:46 HD Request # 35 | Requesting Intraday data. Start Date-Time: 2016-01-20 14:29:49. Record interval: 2. Symbol: CLG6 | 2016-03-13 21:50:46 HD Request # 35 | Decompressing data. | 2016-03-13 21:50:46 HD Request # 35 | Receiving Intraday data for CLG6 starting at 2016-01-20 14:29:49 | 2016-03-13 21:50:46 HD Request # 35 | Timestamp of first Intraday data file record written: 2016-01-20 14:29:49 | 2016-03-13 21:50:46 Socket (24) | Shutdown and closed. | 2016-03-13 21:50:46 The network socket for historical data has been closed. | 2016-03-13 21:50:46 HD Request # 35 | Received 1 record from 2016-01-20 14:29:49 to 2016-01-20 14:29:49 (0.0 seconds) and wrote 1 record for CLG6 | 2016-03-13 21:50:46 HD Request # 35 | Intraday download COMPLETE for CLG6. Completion time: 1s. Unique request ID: 34 | 2016-03-13 21:50:46 Removed historical data download ID 34 | 2016-03-13 21:50:46 Real-time Intraday chart data file updates started for CLG6 | 2016-03-13 21:50:46 Opened cached Intraday file: C:\SierraChart\Data\CLG6.scid | 2016-03-13 21:50:46 Intraday chart data file opened for CLG6 | 2016-03-13 21:50:46 HD Request # 36 | Downloading Intraday chart data for TFH6 to the file TFH6.scid. Service: ta | 2016-03-13 21:50:46 HD Request # 36 | Download start Date-Time: 2016-03-13 21:41:41.000 | 2016-03-13 21:50:46 HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:46 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:46 Socket (25) | Connected. | 2016-03-13 21:50:46 HD Request # 36 | Sending historical data logon request message. | 2016-03-13 21:50:46 HD Request # 36 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:41:41. Record interval: 2. Symbol: TFH6 | 2016-03-13 21:50:46 HD Request # 36 | Decompressing data. | 2016-03-13 21:50:47 HD Request # 36 | Receiving Intraday data for TFH6 starting at 2016-03-13 21:41:41 | 2016-03-13 21:50:47 HD Request # 36 | Timestamp of first Intraday data file record written: 2016-03-13 21:41:41 | 2016-03-13 21:50:47 Socket (25) | Shutdown and closed. | 2016-03-13 21:50:47 The network socket for historical data has been closed. | 2016-03-13 21:50:47 HD Request # 36 | Received 1 record from 2016-03-13 21:41:41 to 2016-03-13 21:41:41 (0.0 seconds) and wrote 1 record for TFH6 | 2016-03-13 21:50:47 HD Request # 36 | Intraday download COMPLETE for TFH6. Completion time: 0s. Unique request ID: 35 | 2016-03-13 21:50:47 Removed historical data download ID 35 | 2016-03-13 21:50:47 Real-time Intraday chart data file updates started for TFH6 | 2016-03-13 21:50:47 Opened cached Intraday file: C:\SierraChart\Data\TFH6.scid | 2016-03-13 21:50:47 Intraday chart data file opened for TFH6 | 2016-03-13 21:50:47 HD Request # 37 | Downloading Intraday chart data for YMH6 to the file YMH6.scid. Service: ta | 2016-03-13 21:50:47 HD Request # 37 | Download start Date-Time: 2016-03-13 21:43:33.000 | 2016-03-13 21:50:47 HD Request # 37 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:50:47 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:50:47 Socket (26) | Connected. | 2016-03-13 21:50:47 HD Request # 37 | Sending historical data logon request message. | 2016-03-13 21:50:47 HD Request # 37 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:43:33. Record interval: 2. Symbol: YMH6 | 2016-03-13 21:50:47 HD Request # 37 | Decompressing data. | 2016-03-13 21:50:47 HD Request # 37 | Receiving Intraday data for YMH6 starting at 2016-03-13 21:43:33 | 2016-03-13 21:50:47 HD Request # 37 | Timestamp of first Intraday data file record written: 2016-03-13 21:43:33 | 2016-03-13 21:50:47 Socket (26) | Shutdown and closed. | 2016-03-13 21:50:47 The network socket for historical data has been closed. | 2016-03-13 21:50:47 HD Request # 37 | Received 9 records from 2016-03-13 21:43:33 to 2016-03-13 21:47:26 (3.9 minutes) and wrote 9 records for YMH6 | 2016-03-13 21:50:47 HD Request # 37 | Intraday download COMPLETE for YMH6. Completion time: 0s. Unique request ID: 36 | 2016-03-13 21:50:47 Removed historical data download ID 36 | 2016-03-13 21:50:47 Real-time Intraday chart data file updates started for YMH6 | 2016-03-13 21:50:47 Opened cached Intraday file: C:\SierraChart\Data\YMH6.scid | 2016-03-13 21:50:47 Intraday chart data file opened for YMH6 | 2016-03-13 21:50:47 HD Request # 38 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-03-13 21:50:47 HD Request # 38 | Download start Date-Time: 2016-03-13 21:44:06.000 | 2016-03-13 21:50:47 HD Request # 38 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 21:50:47 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 21:50:47 Socket (27) | Connected. | 2016-03-13 21:50:47 HD Request # 38 | Sending historical data logon request message. | 2016-03-13 21:50:47 HD Request # 38 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:44:06. Record interval: 2. Symbol: ESH6 | 2016-03-13 21:50:47 HD Request # 38 | Decompressing data. | 2016-03-13 21:50:47 HD Request # 38 | Receiving Intraday data for ESH6 starting at 2016-03-13 21:44:06 | 2016-03-13 21:50:47 HD Request # 38 | Timestamp of first Intraday data file record written: 2016-03-13 21:44:06 | 2016-03-13 21:50:47 Socket (27) | Shutdown and closed. | 2016-03-13 21:50:47 The network socket for historical data has been closed. | 2016-03-13 21:50:47 HD Request # 38 | Received 51 records from 2016-03-13 21:44:06 to 2016-03-13 21:50:21 (6.2 minutes) and wrote 51 records for ESH6 | 2016-03-13 21:50:47 HD Request # 38 | Intraday download COMPLETE for ESH6. Completion time: 0s. Unique request ID: 37 | 2016-03-13 21:50:47 Removed historical data download ID 37 | 2016-03-13 21:50:47 Real-time Intraday chart data file updates started for ESH6 | 2016-03-13 21:50:47 Opened cached Intraday file: C:\SierraChart\Data\ESH6.scid | 2016-03-13 21:50:47 Intraday chart data file opened for ESH6 | 2016-03-13 21:50:47 HD Request # 39 | Downloading Intraday chart data for ESz5 to the file ESz5.scid. Service: ta | 2016-03-13 21:50:47 HD Request # 39 | Download start Date-Time: 2015-12-18 09:43:52.000 | 2016-03-13 21:50:47 HD Request # 39 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 21:50:47 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 21:50:47 Socket (28) | Connected. | 2016-03-13 21:50:47 HD Request # 39 | Sending historical data logon request message. | 2016-03-13 21:50:47 HD Request # 39 | Requesting Intraday data. Start Date-Time: 2015-12-18 09:43:52. Record interval: 2. Symbol: ESz5 | 2016-03-13 21:50:47 HD Request # 39 | Decompressing data. | 2016-03-13 21:50:47 HD Request # 39 | Receiving Intraday data for ESz5 starting at 2015-09-23 10:43:44 | 2016-03-13 21:50:47 Socket (28) | Shutdown and closed. | 2016-03-13 21:51:32 The network socket for historical data has been closed. | 2016-03-13 21:51:32 HD Request # 39 | Received 1357491 records from 2015-09-23 10:43:44 to 2015-12-18 09:43:44 (86.0 days) and wrote 0 records for ESz5 | 2016-03-13 21:51:32 HD Request # 39 | Intraday download COMPLETE for ESz5. Completion time: 45s. Unique request ID: 38 | 2016-03-13 21:51:32 Removed historical data download ID 38 | 2016-03-13 21:51:32 Real-time Intraday chart data file updates started for ESz5 | 2016-03-13 21:51:32 Opened cached Intraday file: C:\SierraChart\Data\ESz5.scid | 2016-03-13 21:51:32 Intraday chart data file opened for ESz5 | 2016-03-13 21:51:32 HD Request # 40 | Downloading Intraday chart data for NQM6 to the file NQM6.scid. Service: ta | 2016-03-13 21:51:32 HD Request # 40 | Download start Date-Time: 2016-03-13 21:40:02.000 | 2016-03-13 21:51:32 HD Request # 40 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 21:51:32 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 21:51:32 Socket (29) | Connected. | 2016-03-13 21:51:32 HD Request # 40 | Sending historical data logon request message. | 2016-03-13 21:51:32 HD Request # 40 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:40:02. Record interval: 2. Symbol: NQM6 | 2016-03-13 21:51:32 HD Request # 40 | Decompressing data. | 2016-03-13 21:51:32 HD Request # 40 | Receiving Intraday data for NQM6 starting at 2016-03-13 21:40:02 | 2016-03-13 21:51:32 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-03-13 21:40:02 | 2016-03-13 21:51:32 Socket (29) | Shutdown and closed. | 2016-03-13 21:51:32 The network socket for historical data has been closed. | 2016-03-13 21:51:32 HD Request # 40 | Received 48 records from 2016-03-13 21:40:02 to 2016-03-13 21:50:30 (10.5 minutes) and wrote 48 records for NQM6 | 2016-03-13 21:51:32 HD Request # 40 | Intraday download COMPLETE for NQM6. Completion time: 0s. Unique request ID: 39 | 2016-03-13 21:51:32 Removed historical data download ID 39 | 2016-03-13 21:51:32 Real-time Intraday chart data file updates started for NQM6 | 2016-03-13 21:51:32 Opened cached Intraday file: C:\SierraChart\Data\NQM6.scid | 2016-03-13 21:51:32 Intraday chart data file opened for NQM6 | 2016-03-13 21:51:32 HTTP connection to ds01.ddfplus.com:80 (4) | Closed. No error. | 2016-03-13 21:51:32 HTTP connection to ds01.ddfplus.com:80 (4) | Shutdown and closed. | 2016-03-13 21:51:32 File >> Disconnect selected. | 2016-03-13 21:57:55 Socket (16) | Shutdown and closed. | 2016-03-13 21:57:55 Socket (17) | Shutdown and closed. | 2016-03-13 21:57:55 SC DTC Data | Disconnected from the server. | 2016-03-13 21:57:55 TransAct Trading | Disconnected. | 2016-03-13 21:57:55 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 21:58:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:58:03 Socket (33) | Connected. | 2016-03-13 21:58:03 TransAct Trading | Connected to server. | 2016-03-13 21:58:03 TransAct Trading | Sending logon request message. | 2016-03-13 21:58:03 TransAct Trading | Market data feed reported to be lost. | 2016-03-13 21:58:24 TransAct Trading | Received logon response. | 2016-03-13 21:58:24 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 21:58:24 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 21:58:24 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 21:58:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:58:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:58:24 Socket (33) | Shutdown and closed. | 2016-03-13 21:58:24 TransAct Trading | Disconnected. | 2016-03-13 21:58:24 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:58:24 TransAct Trading | Bridge process is still running. | 2016-03-13 21:58:29 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:58:31 Socket (35) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:58:32 Socket (35) | Shutdown and closed. | 2016-03-13 21:58:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:58:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:58:32 TransAct Trading | Disconnected. | 2016-03-13 21:58:32 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:58:32 TransAct Trading | Bridge process is still running. | 2016-03-13 21:58:37 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:58:39 Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:58:40 Socket (36) | Shutdown and closed. | 2016-03-13 21:58:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:58:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:58:40 TransAct Trading | Disconnected. | 2016-03-13 21:58:40 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:58:40 TransAct Trading | Bridge process is still running. | 2016-03-13 21:58:46 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:58:48 Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:58:49 Socket (37) | Shutdown and closed. | 2016-03-13 21:58:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:58:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:58:49 TransAct Trading | Disconnected. | 2016-03-13 21:58:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:58:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 21:58:54 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:58:56 Socket (38) | Connected. | 2016-03-13 21:58:56 TransAct Trading | Connected to server. | 2016-03-13 21:58:56 TransAct Trading | Sending logon request message. | 2016-03-13 21:58:56 TransAct Trading | Market data feed reported to be lost. | 2016-03-13 21:59:16 TransAct Trading | Received logon response. | 2016-03-13 21:59:16 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 21:59:16 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 21:59:16 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 21:59:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:59:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:59:16 Socket (38) | Shutdown and closed. | 2016-03-13 21:59:16 TransAct Trading | Disconnected. | 2016-03-13 21:59:16 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:59:16 TransAct Trading | Bridge process is still running. | 2016-03-13 21:59:22 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:59:24 Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:59:25 Socket (39) | Shutdown and closed. | 2016-03-13 21:59:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:59:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:59:25 TransAct Trading | Disconnected. | 2016-03-13 21:59:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:59:25 TransAct Trading | Bridge process is still running. | 2016-03-13 21:59:30 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:59:32 Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:59:33 Socket (40) | Shutdown and closed. | 2016-03-13 21:59:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:59:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:59:33 TransAct Trading | Disconnected. | 2016-03-13 21:59:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:59:33 TransAct Trading | Bridge process is still running. | 2016-03-13 21:59:38 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 21:59:40 Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-13 21:59:41 Socket (41) | Shutdown and closed. | 2016-03-13 21:59:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 21:59:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 21:59:41 TransAct Trading | Disconnected. | 2016-03-13 21:59:41 Will reconnect to the server in 35.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 21:59:41 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 22:00:16 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 22:00:18 Socket (43) | Connected. | 2016-03-13 22:00:18 TransAct Trading | Connected to server. | 2016-03-13 22:00:18 TransAct Trading | Sending logon request message. | 2016-03-13 22:00:18 TransAct Trading | Market data feed reported to be lost. | 2016-03-13 22:00:39 TransAct Trading | Received logon response. | 2016-03-13 22:00:39 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:00:39 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:00:39 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 22:00:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 22:00:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 22:00:39 Socket (43) | Shutdown and closed. | 2016-03-13 22:00:39 TransAct Trading | Disconnected. | 2016-03-13 22:00:39 Will reconnect to the server in 45.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 22:00:39 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 22:01:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 22:01:26 Socket (44) | Connected. | 2016-03-13 22:01:26 TransAct Trading | Connected to server. | 2016-03-13 22:01:26 TransAct Trading | Sending logon request message. | 2016-03-13 22:01:26 TransAct Trading | Market data feed reported to be lost. | 2016-03-13 22:01:47 TransAct Trading | Received logon response. | 2016-03-13 22:01:47 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:01:47 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:01:47 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 22:01:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 22:01:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 22:01:47 Socket (44) | Shutdown and closed. | 2016-03-13 22:01:47 TransAct Trading | Disconnected. | 2016-03-13 22:01:47 Will reconnect to the server in 50.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 22:01:47 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 22:02:37 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 22:02:39 Socket (46) | Connected. | 2016-03-13 22:02:39 TransAct Trading | Connected to server. | 2016-03-13 22:02:39 TransAct Trading | Sending logon request message. | 2016-03-13 22:02:39 TransAct Trading | Market data feed reported to be lost. | 2016-03-13 22:03:00 TransAct Trading | Received logon response. | 2016-03-13 22:03:00 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:03:00 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:03:00 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 22:03:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-13 22:03:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-13 22:03:00 Socket (46) | Shutdown and closed. | 2016-03-13 22:03:00 TransAct Trading | Disconnected. | 2016-03-13 22:03:00 Will reconnect to the server in 60.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-13 22:03:00 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 22:04:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 22:04:02 Socket (47) | Connected. | 2016-03-13 22:04:02 TransAct Trading | Connected to server. | 2016-03-13 22:04:02 TransAct Trading | Sending logon request message. | 2016-03-13 22:04:02 TransAct Trading | Received logon response. | 2016-03-13 22:04:04 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:04:04 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:04:04 TransAct Trading | Successfully connected. Operation Successful. | 2016-03-13 22:04:04 TransAct Trading | Connected to data and trading server. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: CLN5. ID: 1 | 2016-03-13 22:04:04 Intraday data recording state for symbol CLN5 is set to download 'Pending'. | 2016-03-13 22:04:04 Symbol Error - CLN5 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 Delaying start of download for CLN5 | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: YMH6. ID: 2 | 2016-03-13 22:04:04 Intraday data recording state for symbol YMH6 is set to download 'Pending'. | 2016-03-13 22:04:04 HD Request # 41 | Downloading Intraday chart data for CLN5 to the file CLN5.scid. Service: ta | 2016-03-13 22:04:04 HD Request # 41 | Download start Date-Time: 2015-06-22 14:29:54.000 | 2016-03-13 22:04:04 HD Request # 41 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 22:04:04 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:04 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 3 | 2016-03-13 22:04:04 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-03-13 22:04:04 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: EXR. ID: 4 | 2016-03-13 22:04:04 Symbol Error - EXR is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 Socket (48) | Connected. | 2016-03-13 22:04:04 HD Request # 41 | Sending historical data logon request message. | 2016-03-13 22:04:04 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2016-03-13 22:04:04 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 10048 | 2016-03-13 22:04:04 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-03-13 22:04:04 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 6 | 2016-03-13 22:04:04 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-03-13 22:04:04 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 7 | 2016-03-13 22:04:04 Intraday data recording state for symbol TFM6 is set to download 'Pending'. | 2016-03-13 22:04:04 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: $NYA. ID: 8 | 2016-03-13 22:04:04 Symbol Error - $NYA is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: YMM6. ID: 9 | 2016-03-13 22:04:04 Intraday data recording state for symbol YMM6 is set to download 'Pending'. | 2016-03-13 22:04:04 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: NQH6. ID: 10 | 2016-03-13 22:04:04 Intraday data recording state for symbol NQH6 is set to download 'Pending'. | 2016-03-13 22:04:04 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:04 HD Request # 41 | Requesting Intraday data. Start Date-Time: 2015-06-22 14:29:54. Record interval: 2. Symbol: CLN5 | 2016-03-13 22:04:04 Socket (49) | Connected. | 2016-03-13 22:04:04 SC DTC Data | Connected to server. | 2016-03-13 22:04:04 SC DTC Data | Sending Encoding Request to server | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: YM#. ID: 11 | 2016-03-13 22:04:04 Not starting updates for a symbol containing a #: YM# | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: $INX. ID: 12 | 2016-03-13 22:04:04 Symbol Error - $INX is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: CLG6. ID: 13 | 2016-03-13 22:04:04 Intraday data recording state for symbol CLG6 is set to download 'Pending'. | 2016-03-13 22:04:04 Symbol Error - CLG6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: TFH6. ID: 14 | 2016-03-13 22:04:04 Intraday data recording state for symbol TFH6 is set to download 'Pending'. | 2016-03-13 22:04:04 Symbol Error - TFH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-03-13 22:04:04 SC DTC Data | Sending logon request message. | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: $INDU. ID: 15 | 2016-03-13 22:04:04 Symbol Error - $INDU is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: IWM. ID: 16 | 2016-03-13 22:04:04 Symbol Error - IWM is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:04 TransAct Trading | Starting real-time market data updates for: XRT. ID: 17 | 2016-03-13 22:04:05 Symbol Error - XRT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: IYT. ID: 18 | 2016-03-13 22:04:05 Symbol Error - IYT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: SMH. ID: 19 | 2016-03-13 22:04:05 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: KRE. ID: 20 | 2016-03-13 22:04:05 Symbol Error - KRE is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: NQ#. ID: 21 | 2016-03-13 22:04:05 Not starting updates for a symbol containing a #: NQ# | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: IBB. ID: 22 | 2016-03-13 22:04:05 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: ESz5. ID: 23 | 2016-03-13 22:04:05 Intraday data recording state for symbol ESz5 is set to download 'Pending'. | 2016-03-13 22:04:05 HD Request # 41 | Decompressing data. | 2016-03-13 22:04:05 Symbol Error - ESz5 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 HD Request # 41 | Receiving Intraday data for CLN5 starting at 2015-06-22 14:29:54 | 2016-03-13 22:04:05 HD Request # 41 | Timestamp of first Intraday data file record written: 2015-06-22 14:29:54 | 2016-03-13 22:04:05 Socket (48) | Shutdown and closed. | 2016-03-13 22:04:05 The network socket for historical data has been closed. | 2016-03-13 22:04:05 HD Request # 41 | Received 1 record from 2015-06-22 14:29:54 to 2015-06-22 14:29:54 (0.0 seconds) and wrote 1 record for CLN5 | 2016-03-13 22:04:05 HD Request # 41 | Intraday download COMPLETE for CLN5. Completion time: 0s. Unique request ID: 40 | 2016-03-13 22:04:05 Removed historical data download ID 40 | 2016-03-13 22:04:05 Real-time Intraday chart data file updates started for CLN5 | 2016-03-13 22:04:05 Opened cached Intraday file: C:\SierraChart\Data\CLN5.scid | 2016-03-13 22:04:05 Intraday chart data file opened for CLN5 | 2016-03-13 22:04:05 Delaying start of download for YMH6 | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: CHKP. ID: 24 | 2016-03-13 22:04:05 Symbol Error - CHKP is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: ES#. ID: 25 | 2016-03-13 22:04:05 Not starting updates for a symbol containing a #: ES# | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: NQM6. ID: 26 | 2016-03-13 22:04:05 Intraday data recording state for symbol NQM6 is set to download 'Pending'. | 2016-03-13 22:04:05 HD Request # 42 | Downloading Intraday chart data for YMH6 to the file YMH6.scid. Service: ta | 2016-03-13 22:04:05 HD Request # 42 | Download start Date-Time: 2016-03-13 21:47:26.000 | 2016-03-13 22:04:05 HD Request # 42 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 22:04:05 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-03-13 22:04:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 22:04:05 TransAct Trading | Starting real-time market data updates for: FDX. ID: 27 | 2016-03-13 22:04:05 Symbol Error - FDX is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-03-13 22:04:05 SC DTC Data | Received logon response. | 2016-03-13 22:04:05 SC DTC Data | Server Name: SC Real-Time Server. | 2016-03-13 22:04:05 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-03-13 22:04:05 SC DTC Data | Successfully connected. | 2016-03-13 22:04:05 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-03-13 22:04:05 Socket (50) | Connected. | 2016-03-13 22:04:05 HD Request # 42 | Sending historical data logon request message. | 2016-03-13 22:04:05 HD Request # 42 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:47:26. Record interval: 2. Symbol: YMH6 | 2016-03-13 22:04:05 HD Request # 42 | Decompressing data. | 2016-03-13 22:04:05 HD Request # 42 | Receiving Intraday data for YMH6 starting at 2016-03-13 21:47:26 | 2016-03-13 22:04:05 HD Request # 42 | Timestamp of first Intraday data file record written: 2016-03-13 21:47:26 | 2016-03-13 22:04:05 Socket (50) | Shutdown and closed. | 2016-03-13 22:04:05 The network socket for historical data has been closed. | 2016-03-13 22:04:05 HD Request # 42 | Received 26 records from 2016-03-13 21:47:26 to 2016-03-13 22:02:47 (15.4 minutes) and wrote 26 records for YMH6 | 2016-03-13 22:04:05 HD Request # 42 | Intraday download COMPLETE for YMH6. Completion time: 0s. Unique request ID: 41 | 2016-03-13 22:04:05 Removed historical data download ID 41 | 2016-03-13 22:04:05 Real-time Intraday chart data file updates started for YMH6 | 2016-03-13 22:04:05 Opened cached Intraday file: C:\SierraChart\Data\YMH6.scid | 2016-03-13 22:04:05 Intraday chart data file opened for YMH6 | 2016-03-13 22:04:05 Delaying start of download for ESH6 | 2016-03-13 22:04:05 HD Request # 43 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-03-13 22:04:08 HD Request # 43 | Download start Date-Time: 2016-03-13 21:50:21.000 | 2016-03-13 22:04:08 HD Request # 43 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 22:04:08 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 22:04:08 Socket (51) | Connected. | 2016-03-13 22:04:08 HD Request # 43 | Sending historical data logon request message. | 2016-03-13 22:04:08 HD Request # 43 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:50:21. Record interval: 2. Symbol: ESH6 | 2016-03-13 22:04:08 HD Request # 43 | Decompressing data. | 2016-03-13 22:04:08 HD Request # 43 | Receiving Intraday data for ESH6 starting at 2016-03-13 21:50:21 | 2016-03-13 22:04:08 HD Request # 43 | Timestamp of first Intraday data file record written: 2016-03-13 21:50:21 | 2016-03-13 22:04:08 Socket (51) | Shutdown and closed. | 2016-03-13 22:04:08 The network socket for historical data has been closed. | 2016-03-13 22:04:08 HD Request # 43 | Received 50 records from 2016-03-13 21:50:21 to 2016-03-13 22:02:42 (12.4 minutes) and wrote 50 records for ESH6 | 2016-03-13 22:04:08 HD Request # 43 | Intraday download COMPLETE for ESH6. Completion time: 0s. Unique request ID: 42 | 2016-03-13 22:04:08 Removed historical data download ID 42 | 2016-03-13 22:04:08 Real-time Intraday chart data file updates started for ESH6 | 2016-03-13 22:04:08 Opened cached Intraday file: C:\SierraChart\Data\ESH6.scid | 2016-03-13 22:04:08 Intraday chart data file opened for ESH6 | 2016-03-13 22:04:08 Delaying start of download for TICK-NYSE | 2016-03-13 22:04:08 HD Request # 44 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-03-13 22:04:09 HD Request # 44 | Download start Date-Time: 2016-03-11 16:05:00.000 | 2016-03-13 22:04:09 HD Request # 44 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 22:04:09 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 22:04:09 Socket (52) | Connected. | 2016-03-13 22:04:09 HD Request # 44 | Sending historical data logon request message. | 2016-03-13 22:04:09 HD Request # 44 | Requesting Intraday data. Start Date-Time: 2016-03-11 16:05:00. Record interval: 2. Symbol: TICK-NYSE | 2016-03-13 22:04:09 HD Request # 44 | Decompressing data. | 2016-03-13 22:04:10 HD Request # 44 | Receiving Intraday data for TICK-NYSE starting at 2016-03-11 16:05:00 | 2016-03-13 22:04:10 HD Request # 44 | Timestamp of first Intraday data file record written: 2016-03-11 16:05:00 | 2016-03-13 22:04:10 Socket (52) | Shutdown and closed. | 2016-03-13 22:04:10 The network socket for historical data has been closed. | 2016-03-13 22:04:10 HD Request # 44 | Received 1 record from 2016-03-11 16:05:00 to 2016-03-11 16:05:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2016-03-13 22:04:10 HD Request # 44 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 43 | 2016-03-13 22:04:10 Removed historical data download ID 43 | 2016-03-13 22:04:10 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-03-13 22:04:10 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2016-03-13 22:04:10 Intraday chart data file opened for TICK-NYSE | 2016-03-13 22:04:10 HD Request # 45 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-03-13 22:04:10 HD Request # 45 | Download start Date-Time: 2016-03-13 21:49:30.000 | 2016-03-13 22:04:10 HD Request # 45 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 22:04:10 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 22:04:10 Socket (53) | Connected. | 2016-03-13 22:04:10 HD Request # 45 | Sending historical data logon request message. | 2016-03-13 22:04:10 HD Request # 45 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:49:30. Record interval: 2. Symbol: ESM6 | 2016-03-13 22:04:10 HD Request # 45 | Decompressing data. | 2016-03-13 22:04:10 HD Request # 45 | Receiving Intraday data for ESM6 starting at 2016-03-13 21:49:30 | 2016-03-13 22:04:10 HD Request # 45 | Timestamp of first Intraday data file record written: 2016-03-13 21:49:30 | 2016-03-13 22:04:10 Socket (53) | Shutdown and closed. | 2016-03-13 22:04:10 The network socket for historical data has been closed. | 2016-03-13 22:04:10 HD Request # 45 | Received 95 records from 2016-03-13 21:49:30 to 2016-03-13 22:03:19 (13.8 minutes) and wrote 95 records for ESM6 | 2016-03-13 22:04:10 HD Request # 45 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 44 | 2016-03-13 22:04:10 Removed historical data download ID 44 | 2016-03-13 22:04:10 Real-time Intraday chart data file updates started for ESM6 | 2016-03-13 22:04:10 Opened cached Intraday file: C:\SierraChart\Data\ESM6.scid | 2016-03-13 22:04:10 Intraday chart data file opened for ESM6 | 2016-03-13 22:04:10 HD Request # 46 | Downloading Intraday chart data for TFM6 to the file TFM6.scid. Service: ta | 2016-03-13 22:04:10 HD Request # 46 | Download start Date-Time: 2016-03-13 21:42:04.000 | 2016-03-13 22:04:10 HD Request # 46 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 22:04:10 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 22:04:10 Socket (54) | Connected. | 2016-03-13 22:04:10 HD Request # 46 | Sending historical data logon request message. | 2016-03-13 22:04:10 HD Request # 46 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:42:04. Record interval: 2. Symbol: TFM6 | 2016-03-13 22:04:10 HD Request # 46 | Decompressing data. | 2016-03-13 22:04:10 HD Request # 46 | Receiving Intraday data for TFM6 starting at 2016-03-13 21:42:04 | 2016-03-13 22:04:10 HD Request # 46 | Timestamp of first Intraday data file record written: 2016-03-13 21:42:04 | 2016-03-13 22:04:10 Socket (54) | Shutdown and closed. | 2016-03-13 22:04:10 The network socket for historical data has been closed. | 2016-03-13 22:04:10 HD Request # 46 | Received 7 records from 2016-03-13 21:42:04 to 2016-03-13 22:00:29 (18.4 minutes) and wrote 7 records for TFM6 | 2016-03-13 22:04:10 HD Request # 46 | Intraday download COMPLETE for TFM6. Completion time: 1s. Unique request ID: 45 | 2016-03-13 22:04:10 Removed historical data download ID 45 | 2016-03-13 22:04:10 Real-time Intraday chart data file updates started for TFM6 | 2016-03-13 22:04:10 Opened cached Intraday file: C:\SierraChart\Data\TFM6.scid | 2016-03-13 22:04:10 Intraday chart data file opened for TFM6 | 2016-03-13 22:04:10 HD Request # 47 | Downloading Intraday chart data for YMM6 to the file YMM6.scid. Service: ta | 2016-03-13 22:04:10 HD Request # 47 | Download start Date-Time: 2016-03-13 21:50:34.000 | 2016-03-13 22:04:10 HD Request # 47 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 22:04:10 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 22:04:10 Socket (55) | Connected. | 2016-03-13 22:04:10 HD Request # 47 | Sending historical data logon request message. | 2016-03-13 22:04:10 HD Request # 47 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:50:34. Record interval: 2. Symbol: YMM6 | 2016-03-13 22:04:10 HD Request # 47 | Decompressing data. | 2016-03-13 22:04:10 HD Request # 47 | Receiving Intraday data for YMM6 starting at 2016-03-13 21:50:34 | 2016-03-13 22:04:10 HD Request # 47 | Timestamp of first Intraday data file record written: 2016-03-13 21:50:34 | 2016-03-13 22:04:10 Socket (55) | Shutdown and closed. | 2016-03-13 22:04:10 The network socket for historical data has been closed. | 2016-03-13 22:04:10 HD Request # 47 | Received 36 records from 2016-03-13 21:50:34 to 2016-03-13 22:03:01 (12.5 minutes) and wrote 36 records for YMM6 | 2016-03-13 22:04:10 HD Request # 47 | Intraday download COMPLETE for YMM6. Completion time: 0s. Unique request ID: 46 | 2016-03-13 22:04:10 Removed historical data download ID 46 | 2016-03-13 22:04:10 Real-time Intraday chart data file updates started for YMM6 | 2016-03-13 22:04:10 Opened cached Intraday file: C:\SierraChart\Data\YMM6.scid | 2016-03-13 22:04:10 Intraday chart data file opened for YMM6 | 2016-03-13 22:04:10 HD Request # 48 | Downloading Intraday chart data for NQH6 to the file NQH6.scid. Service: ta | 2016-03-13 22:04:10 HD Request # 48 | Download start Date-Time: 2016-03-13 21:48:06.000 | 2016-03-13 22:04:10 HD Request # 48 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 22:04:10 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 22:04:10 Socket (56) | Connected. | 2016-03-13 22:04:10 HD Request # 48 | Sending historical data logon request message. | 2016-03-13 22:04:10 HD Request # 48 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:48:06. Record interval: 2. Symbol: NQH6 | 2016-03-13 22:04:10 HD Request # 48 | Decompressing data. | 2016-03-13 22:04:10 HD Request # 48 | Receiving Intraday data for NQH6 starting at 2016-03-13 21:48:06 | 2016-03-13 22:04:10 HD Request # 48 | Timestamp of first Intraday data file record written: 2016-03-13 21:48:06 | 2016-03-13 22:04:10 Socket (56) | Shutdown and closed. | 2016-03-13 22:04:10 The network socket for historical data has been closed. | 2016-03-13 22:04:10 HD Request # 48 | Received 17 records from 2016-03-13 21:48:06 to 2016-03-13 22:03:26 (15.3 minutes) and wrote 17 records for NQH6 | 2016-03-13 22:04:10 HD Request # 48 | Intraday download COMPLETE for NQH6. Completion time: 0s. Unique request ID: 47 | 2016-03-13 22:04:10 Removed historical data download ID 47 | 2016-03-13 22:04:10 Real-time Intraday chart data file updates started for NQH6 | 2016-03-13 22:04:10 Opened cached Intraday file: C:\SierraChart\Data\NQH6.scid | 2016-03-13 22:04:10 Intraday chart data file opened for NQH6 | 2016-03-13 22:04:10 HD Request # 49 | Downloading Intraday chart data for CLG6 to the file CLG6.scid. Service: ta | 2016-03-13 22:04:10 HD Request # 49 | Download start Date-Time: 2016-01-20 14:29:49.000 | 2016-03-13 22:04:10 HD Request # 49 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 22:04:10 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 22:04:10 Socket (57) | Connected. | 2016-03-13 22:04:10 HD Request # 49 | Sending historical data logon request message. | 2016-03-13 22:04:10 HD Request # 49 | Requesting Intraday data. Start Date-Time: 2016-01-20 14:29:49. Record interval: 2. Symbol: CLG6 | 2016-03-13 22:04:11 HD Request # 49 | Decompressing data. | 2016-03-13 22:04:11 HD Request # 49 | Receiving Intraday data for CLG6 starting at 2016-01-20 14:29:49 | 2016-03-13 22:04:11 HD Request # 49 | Timestamp of first Intraday data file record written: 2016-01-20 14:29:49 | 2016-03-13 22:04:11 Socket (57) | Shutdown and closed. | 2016-03-13 22:04:11 The network socket for historical data has been closed. | 2016-03-13 22:04:11 HD Request # 49 | Received 1 record from 2016-01-20 14:29:49 to 2016-01-20 14:29:49 (0.0 seconds) and wrote 1 record for CLG6 | 2016-03-13 22:04:11 HD Request # 49 | Intraday download COMPLETE for CLG6. Completion time: 0s. Unique request ID: 48 | 2016-03-13 22:04:11 Removed historical data download ID 48 | 2016-03-13 22:04:11 Real-time Intraday chart data file updates started for CLG6 | 2016-03-13 22:04:11 Opened cached Intraday file: C:\SierraChart\Data\CLG6.scid | 2016-03-13 22:04:11 Intraday chart data file opened for CLG6 | 2016-03-13 22:04:11 HD Request # 50 | Downloading Intraday chart data for TFH6 to the file TFH6.scid. Service: ta | 2016-03-13 22:04:11 HD Request # 50 | Download start Date-Time: 2016-03-13 21:41:41.000 | 2016-03-13 22:04:11 HD Request # 50 | Using server: ds4.sierracharts.com port 10149 | 2016-03-13 22:04:11 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-03-13 22:04:11 Socket (58) | Connected. | 2016-03-13 22:04:11 HD Request # 50 | Sending historical data logon request message. | 2016-03-13 22:04:11 HD Request # 50 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:41:41. Record interval: 2. Symbol: TFH6 | 2016-03-13 22:04:11 HD Request # 50 | Decompressing data. | 2016-03-13 22:04:11 HD Request # 50 | Receiving Intraday data for TFH6 starting at 2016-03-13 21:41:41 | 2016-03-13 22:04:11 HD Request # 50 | Timestamp of first Intraday data file record written: 2016-03-13 21:41:41 | 2016-03-13 22:04:11 Socket (58) | Shutdown and closed. | 2016-03-13 22:04:11 The network socket for historical data has been closed. | 2016-03-13 22:04:11 HD Request # 50 | Received 2 records from 2016-03-13 21:41:41 to 2016-03-13 21:57:12 (15.5 minutes) and wrote 2 records for TFH6 | 2016-03-13 22:04:11 HD Request # 50 | Intraday download COMPLETE for TFH6. Completion time: 0s. Unique request ID: 49 | 2016-03-13 22:04:11 Removed historical data download ID 49 | 2016-03-13 22:04:11 Real-time Intraday chart data file updates started for TFH6 | 2016-03-13 22:04:11 Opened cached Intraday file: C:\SierraChart\Data\TFH6.scid | 2016-03-13 22:04:11 Intraday chart data file opened for TFH6 | 2016-03-13 22:04:11 HD Request # 51 | Downloading Intraday chart data for ESz5 to the file ESz5.scid. Service: ta | 2016-03-13 22:04:11 HD Request # 51 | Download start Date-Time: 2015-12-18 09:43:52.000 | 2016-03-13 22:04:11 HD Request # 51 | Using server: ds3.sierracharts.com port 10149 | 2016-03-13 22:04:11 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-03-13 22:04:11 Socket (59) | Connected. | 2016-03-13 22:04:11 HD Request # 51 | Sending historical data logon request message. | 2016-03-13 22:04:11 HD Request # 51 | Requesting Intraday data. Start Date-Time: 2015-12-18 09:43:52. Record interval: 2. Symbol: ESz5 | 2016-03-13 22:04:11 HD Request # 51 | Decompressing data. | 2016-03-13 22:04:12 HD Request # 51 | Receiving Intraday data for ESz5 starting at 2015-09-23 10:43:44 | 2016-03-13 22:04:12 Socket (59) | Shutdown and closed. | 2016-03-13 22:04:34 The network socket for historical data has been closed. | 2016-03-13 22:04:34 HD Request # 51 | Received 1357471 records from 2015-09-23 10:43:44 to 2015-12-18 09:43:44 (86.0 days) and wrote 0 records for ESz5 | 2016-03-13 22:04:34 HD Request # 51 | Intraday download COMPLETE for ESz5. Completion time: 23s. Unique request ID: 50 | 2016-03-13 22:04:34 Removed historical data download ID 50 | 2016-03-13 22:04:34 Real-time Intraday chart data file updates started for ESz5 | 2016-03-13 22:04:34 Opened cached Intraday file: C:\SierraChart\Data\ESz5.scid | 2016-03-13 22:04:34 Intraday chart data file opened for ESz5 | 2016-03-13 22:04:34 HD Request # 52 | Downloading Intraday chart data for NQM6 to the file NQM6.scid. Service: ta | 2016-03-13 22:04:34 HD Request # 52 | Download start Date-Time: 2016-03-13 21:50:30.000 | 2016-03-13 22:04:34 HD Request # 52 | Using server: ds5.sierracharts.com port 10149 | 2016-03-13 22:04:34 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-03-13 22:04:34 Socket (61) | Connected. | 2016-03-13 22:04:34 HD Request # 52 | Sending historical data logon request message. | 2016-03-13 22:04:34 HD Request # 52 | Requesting Intraday data. Start Date-Time: 2016-03-13 21:50:30. Record interval: 2. Symbol: NQM6 | 2016-03-13 22:04:34 HD Request # 52 | Decompressing data. | 2016-03-13 22:04:34 HD Request # 52 | Receiving Intraday data for NQM6 starting at 2016-03-13 21:50:30 | 2016-03-13 22:04:34 HD Request # 52 | Timestamp of first Intraday data file record written: 2016-03-13 21:50:30 | 2016-03-13 22:04:34 Socket (61) | Shutdown and closed. | 2016-03-13 22:04:34 The network socket for historical data has been closed. | 2016-03-13 22:04:34 HD Request # 52 | Received 40 records from 2016-03-13 21:50:30 to 2016-03-13 22:03:24 (12.9 minutes) and wrote 40 records for NQM6 | 2016-03-13 22:04:34 HD Request # 52 | Intraday download COMPLETE for NQM6. Completion time: 0s. Unique request ID: 51 | 2016-03-13 22:04:34 Removed historical data download ID 51 | 2016-03-13 22:04:34 Real-time Intraday chart data file updates started for NQM6 | 2016-03-13 22:04:34 Opened cached Intraday file: C:\SierraChart\Data\NQM6.scid | 2016-03-13 22:04:34 Intraday chart data file opened for NQM6 | 2016-03-13 22:04:34 |
| [2016-03-14 03:41:58] |
We do see the error code 60: TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:03:00 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:03:00 TransAct Trading | Connection error: Unknown Error Code: 60. | 2016-03-13 22:03:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-03-13 22:04:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-03-13 22:04:02 Socket (47) | Connected. | 2016-03-13 22:04:02 TransAct Trading | Connected to server. | 2016-03-13 22:04:02 TransAct Trading | Sending logon request message. | 2016-03-13 22:04:02 TransAct Trading | Received logon response. | 2016-03-13 22:04:04 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-03-13 22:04:04 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-03-13 22:04:04 TransAct Trading | Successfully connected. Operation Successful. | 2016-03-13 22:04:04 TransAct Trading | Connected to data and trading server. | 2016-03-13 22:04:04 And then after this there is a successful connection. If you still lose the connection and encounter error code 60, then refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#ConnectivityRelatedError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
