Date/Time: Mon, 05 Oct 2026 20:10:49 +0000
Bracket order Entry
View Count: 1770
| [2016-03-13 18:40:48] |
| Netz - Posts: 19 |
Hello. Is there a way to setup bracket ENTRY orders (straddle)? Buy stop when # of ticks above current price (when order is entered) and sell stop when # of ticks below current price (when order is entered)? Then cancel the other parent order when one is filled? Also having child OCO attached to each parent. Any functions for time based entries? I assume we can achieve this buy using seconds chart and enter at next bar for precise seconds. I'm exploring Event driven (News) strategies. Thanks! |
| [2016-03-13 19:35:30] |
This is supported. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#OCOBuyStopSellStop Any functions for time based entries? I assume we can achieve this buy using seconds chart and enter at next bar for precise seconds. Have a look at the Spreadsheet System for Trading study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-15 14:37:51] |
| Netz - Posts: 19 |
Thanks for the reply and info. I have been testing the entries on the Dom. Is there a way to create a button on the chart or Dom for oco buy/sell limt/stop order entry? For the Dom I had to right-click somewhere at the left of the price ladder, then select the oco order (bracket). Some use oco (bracket orders) as a straddle to anticipated volatility. If we have go through several steps to place order that would hinder this process. Thanks! |
| [2016-03-15 19:03:48] |
These order types can also be directly entered from the Trade Window: Basic Trading and the Trade Window: Entering an Order from the Trade Window You need to select the Order Type that you want. Also refer to: Chart Trading and the Chart DOM: Entering an OCO Auto-Set Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
