Date/Time: Mon, 05 Oct 2026 19:58:37 +0000
Horizontal T&S
View Count: 1113
| [2016-03-13 18:09:50] |
| sierra28 - Posts: 120 |
Possible to had this feature.It is very usefull for scalper who have to look at price action, workflow in the T&S and limit orders in the book at the same time. Of course you have a t&S but it is far from price action and limit order and i don't have eyes like a chameleon. ;-) Date Time Of Last Edit: 2016-03-13 19:07:24
| [2016-03-13 21:59:39] |
This is supported by using these studies here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s122 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-14 09:16:31] |
Hello, ok but it is display in a subchart isn't it ? it would be very interesting that T&S follow price action in the main chart near the Dom chart. Date Time Of Last Edit: 2016-03-14 09:19:09
| [2016-03-14 09:40:16] |
Yes, it is below the main chart at the bottom.
| [2016-03-14 18:40:08] |
Well, any chance you display T&S directly in main chart like attachement ?
| [2016-03-14 18:51:45] |
You can try by setting the Chart Region setting to 1 but it is not going to appear as you would expect. If you want us to temporarily activate your Sierra Chart account for testing let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
