Date/Time: Thu, 10 Sep 2026 16:14:36 +0000
Point and figure from studies8.cpp has different results than build in study
View Count: 1528
| [2016-03-13 04:14:09] |
| @sstfrederik - Posts: 413 |
I want to adjust the P and F code slightly, however there is a different outcome between a study compiled with the source code from studies8.cpp and the build in "Point and Figure chart study". When the sc.GraphDrawYype = GDT_POINT_AND_FIGURE_XO; on the self-compiled study there is an X and O for each tick versus the built in study where the X and O are in accordance with the box size. See attached images. Is there an update to the source available? Thanks. Date Time Of Last Edit: 2016-03-13 04:17:37
Private File Private File |
| [2016-03-13 19:39:33] |
Any insights?
| [2016-03-14 21:59:48] |
Would appreciate it if you could have a look at this.
| [2016-03-14 22:18:14] |
Yes, we will be looking at this later today. We have to examine the source code for this.
| [2016-03-14 22:21:14] |
Thanks.
| [2016-03-15 16:32:05] |
Update Sierra Chart to 1381 and look at the source code for the Point and Figure Chart study. You will need to set sc.PointAndFigureXOGraphDrawTypeBoxSize Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-15 20:01:21] |
Thanks for the response. I will have a look right now. Looking good thanks. Date Time Of Last Edit: 2016-03-15 20:22:33
