Date/Time: Thu, 26 Dec 2024 11:22:37 +0000
Layered input variables.
View Count: 724
[2016-03-12 21:35:11] |
@sstfrederik - Posts: 404 |
Are you planning on supporting multiple level input settings? Sub inputs can only be set when the main input is selected. UseMA.SetYesNo(0) UseMA.Somevariable.SetInt(100) Thanks. |
[2016-03-12 23:34:44] |
No.
