Date/Time: Mon, 21 Sep 2026 01:37:02 +0000
Latest update keeps playing sound files even though i have logic to prevent..
View Count: 1394
[2016-03-12 20:59:53]
KhaosTrader - Posts: 128
i just updated to the latest version, I have a sound file that plays when I get a setup, it uses the following code:
    if
        (CurrentBarTime >= AlertTime_Start) &&
        (CurrentBarTime <= AlertTime_Stop) &&
        (!sc.IsFullRecalculation) &&
        (!sc.DownloadingHistoricalData) &&
        AlertNewTradeSetup.GetYesNo() == SC_YES
        SCString Buffer;
        Buffer = "c:\\!TradeAlert_Sounds\\";
        Buffer += SymbolName;
        Buffer += "_Long.wav";
        sc.PlaySound(Buffer.GetChars(), 1);
With the new update, it keeps on playing the sound file when loading the chart...
[2016-03-12 23:38:20]
We have an idea why this is occurring. We are checking on this and will work on a solution.
We will have a new release out probably tomorrow.
[2016-03-13 07:25:39]
Ok thank you... Please let me know when the release that will fix this is released so I can download the right one at the right time...
[2016-03-13 09:20:47]
We were mistaken. We had thought maybe there was an implementation problem with some recent changes to sc.IsFullRecalculation. But we do not see a problem. Refer to the documentation for this member.
It is working properly as documented.
What do you mean by:
There is no way we can test to what you gave us. We need a simple and complete study function.
[2016-03-13 12:26:41]
Ok, I put a sound function on the example code, the only part that is important is the playsound part..
SCSFExport scsf_SoundTester(SCStudyInterfaceRef sc)
  // Section 1 - Set the configuration variables and defaults
  if (sc.SetDefaults)
    sc.GraphName = "Sound Tester";
    // During development set this flag to 1, so the DLL can be rebuilt without restarting Sierra Chart. When development is completed, set it to 0 to improve performance.
    sc.FreeDLL = 1;
    sc.AutoLoop = 1; //Automatic looping is enabled.
    sc.Subgraph[0].Name = "Name";
    sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE;
    sc.Subgraph[0].PrimaryColor = RGB(0, 255, 0);
    sc.Input[0].Name = "Float Input";
    sc.Input[0].SetFloat(0.0f);
    return;
  // Section 2 - Do data processing here
  if
      (sc.GetBarHasClosedStatus(sc.Index) == BHCS_BAR_HAS_CLOSED) &&
      sc.Close[sc.Index - 1] > sc.Close[sc.Index] &&
    //const char* p_Symbol;
    //p_Symbol = sc.Symbol.GetChars();
    SCString Buffer;
    Buffer += "CL";
    Buffer += "_Short.wav";
    //sc.AddMessageToLog("Short alert!",0);
[2016-03-13 12:28:35]
The problem can be seen if you do a Replay Chart.. I do it on a time based chart and see (actually hear) the problem...
[2016-03-13 19:52:06]
We now determined the reason for the problem and it is resolved. There will be a new release out later this evening.
[2016-03-13 19:58:35]
Ok thank you...
[2016-03-15 22:09:02]
There still seems to be an issue.. If I load up several charts (different instruments) at the same time, and while some charts are loading data and others are waiting to load data, I get sound events firing. I have to clear the alert sound queue to make it stop and then it will work properly..
Can you please look into this?
Thank you.
[2016-03-16 02:35:06]
This does not make sense that this would be affected by multiple charts being loaded.
Can you consistently reproduce the issue?
We will have to do more testing but we cannot get to this for another day or so.
[2016-03-16 07:26:38]
It seems that in my code, as chart data is loading , i am getting the sound events firing, as once they are loaded, then i clear the queue its fine.
The reason why I mention multiple charts , is because then there is a lot of data being loaded at the time the program is started.
Ok , thank you for testing this , i understand it will be a day or two, that is fine.
[2016-03-19 04:15:33]
We do see this problem and we are correcting it now.
We will have a new release out later this evening.
[2016-03-19 10:33:46]
Thank you, much appreciated.
[2016-03-19 17:50:53]
This has been released. Update to the latest prerelease.
[2016-03-19 19:47:32]
Hi, I see that there is a PreRelease: 1383 (March 19, 2016), that is on the website, I assume this has the fix... However when will this version become a "current release" version?
I installed the prerelease just now.. but I assume a version that is "current release" would be more stable... ?
[2016-03-20 00:06:57]
Refer to this information here:
https://www.sierrachart.com/index.php?page=doc/download.php#AboutPrereleases
