Date/Time: Tue, 08 Sep 2026 20:44:51 +0000
Hi/Lo For TIme Period Showing Different Results
View Count: 934
| [2016-03-11 18:27:18] |
| AP - Posts: 117 |
http://www.sierrachart.com/image.php?l=1457720706101.png See the image above. Above named study, very popular known as 1st hour of the trade as IB (Initial Balance), showing different levels on Rent 3 tick and 5 Min chart. DO you know the reason why? Please help! |
| [2016-03-11 18:29:15] |
| AP - Posts: 117 |
Same results for Hi/Lo for Time Period Extended - show different levels
| [2016-03-11 18:46:04] |
Uncheck the New Bar at Session Start option in Chart Settings: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) Also, you can still have some slightly different values. You really cannot use this study on variable timeframe bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-11 18:56:43
| [2016-03-11 18:58:48] |
| AP - Posts: 117 |
Yeah, even after the New Bar check/uncheck; while the low was aligned to 5mins on Renko but the High could not get aligned. Not sure with Hi/Lo time, time being the important factor, why does the underlying variable activity bars take precedence. Anyhow, I worked it around with Study Overlay to get the accurate values from the 5 mins chart into the Renko chart. Thanks. |
