Date/Time: Fri, 27 Dec 2024 02:35:01 +0000
Option data
View Count: 693
[2016-03-11 15:12:33] |
User22591 - Posts: 133 |
I think there is a problem getting Option Data between IB and SC. I am trying to use SC trading platform to trade options but the data I am getting is not helpful. Option data on IB platform is good so it should be the same on SC.I have spoken to IB on this issue on several occasions but it has not improve. They said their settings are good. I suggest you talk with them to see how we can correct this problem. Winston 770-645-9998 |
[2016-03-11 18:31:42] |
We need to understand the difference. Post an image of the chart in Sierra Chart set to an option symbol by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image And post an image of the same chart in Interactive Brokers and point out what the difference is. Here are instructions to attach an image file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-11 18:32:11
[2016-03-14 22:14:08] |
One potential problem is that some of the data is getting filtered out. Follow the instructions here to disable the error filter: https://www.sierrachart.com/index.php?page=doc/doc_ErrorFilter.html#DisablingErrorFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
