Date/Time: Thu, 26 Dec 2024 11:30:01 +0000
CTVW
View Count: 821
[2016-03-11 13:02:51] |
infpz - Posts: 826 |
Only shows what you see on the attached image, even though all the fields are selected in chart settings window. Any idea why?
[2016-03-11 17:53:41] |
Check the related settings with the Heikin-Ashi study: https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingStudyNamesValuesVWRDL It is the Heikin-Ashi study settings which is the reason for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
