Date/Time: Fri, 25 Sep 2026 07:06:46 +0000
Function parameters - SCStudyInterfaceRef & SCStudyGraphRef
View Count: 3567
[2016-03-11 04:59:21]
User553714 - Posts: 184
From the reading I have done most of the sc functions and variables are "interface" members so when you are writing a function you use "(SCStudyInterfaceRef sc)" in the function header, for example "SCSFExport scsf_TimeTests(SCStudyInterfaceRef sc)"
1)
I have also seen code samples which use an alternative function header..."(SCStudyGraphRef sc)"
"SCSFExport scsf_SC_TradingCrossOverExample(SCStudyGraphRef sc)" and also many user contributed functions.
I have searched for an answer but have been unable to find one. When should this header be used and is there a list of the member functions/variables?
NB: Thanks so much for your speedy response to my previous support request, this has allowed me to carry on with that task; I look forward to sc.DataFile function change in the next sc release.
[2016-03-11 18:06:59]
SCStudyInterfaceRef and SCStudyGraphRef are the same.
We checked the documentation and found two places where the older one was used. They have been updated.
Refer to:
ACSIL Interface Members - Introduction
