Date/Time: Tue, 14 Jan 2025 02:17:02 +0000
[Programming Help] - Reference Symbol Category in ACSIL
View Count: 768
[2016-03-11 02:41:18] |
rhovega - Posts: 279 |
Hi, I need to make a reference to Forex category in ACSIL, to filter out using volume as trading/signals input for forex symbols. In Symbol Settings symbols have a category. Can I reference this in ACSIL? If so, how? Some data feeds assign volume to forex symbols while some others do not, hence can't use volume as a filter per se. Thanks |
[2016-03-20 19:14:44] |
[2016-03-20 19:22:03] |
This is not accessible from ACSIL.
