Date/Time: Thu, 10 Sep 2026 06:06:45 +0000
Inquiry
View Count: 844
| [2016-03-11 01:01:04] |
| User157806 - Posts: 71 |
Just had a general question if I am using the attached orders for example a 2 contract position with 2 stops and 1 target for both contracts. Let's say when I close out 1 position by using a market order on the DOM for a single lot that work's fine, the downside is it does not adjust the limit quantity to 1 or cancel the 2nd stop order I have working. Is there a scale out function in Sierra that allows me to use to auto adjust those quantities?
| [2016-03-11 02:25:20] |
Yes. Refer to: Attached Orders: Scaling Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
