Date/Time: Fri, 27 Dec 2024 01:47:08 +0000
ESM6-CME not backadusting
View Count: 1000
[2016-03-10 20:45:14]
rhovega - Posts: 279
Today was rollover for ES and Sierra Chart is not backadjusting the symbol with either Date Rule Rollover or Volume Rule Rollover. No such problem with other symbols. This is on the primary instance. Rithmic data feed. Can you help identify the problem?
imageupload.png / V - Attached On 2016-03-10 20:44:28 UTC - Size: 46.91 KB - 259 views
[2016-03-11 02:42:00]
Re-download the data following the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
