Date/Time: Fri, 27 Dec 2024 02:22:32 +0000
Service name for Chicago Mercantile Exchange data service
View Count: 1178
[2016-03-10 19:36:41]
amangalore - Posts: 23
Please let me know the Service name for Chicago Mercantile Exchange data service
Abdulla Mangalore
[2016-03-10 23:36:03]
There is no Service specifically for this. Many supported services provide data from this exchange.
What particular futures market do you want to chart?
[2016-03-11 00:02:44]
I wan to trade S&P 500
[2016-03-11 02:54:22]
Did you require real-time data for this futures contract?
And do you have a futures broker?
[2016-03-11 20:03:20]
No.
Which data service would give me a real time data without delay?
[2016-03-11 20:50:06]
For this you need to activate the Sierra Chart Exchange Data Feed:
This is 35 USD per month.
And you need to activate the exchange:
CME, Globex only (For users without trading accounts) 42 USD/month.
These are both required because you do not have a trading account.
Date Time Of Last Edit: 2016-03-11 20:50:29
[2016-03-11 21:29:46]
Sorry actually I have TD Ameritrade account but not for futures. I got confused. So How do I sign up for realtime data feed with TD Ameritrade thru your web site please ?
Abdulla Mangalore
[2016-03-11 21:49:58]
OK first we want to confirm the cost is acceptable.
We assume the TD Ameritrade account has more than 500 USD in it? This is necessary.
There still is a separate data feed required in the case of TD Ameritrade and the cost will be 38.25 USD per month. Is that acceptable?
This is in addition to what you pay for Sierra Chart.
You can get started for as little as 5 USD for the next two weeks because there is a trial available for this data feed.
If you would like to proceed, put 10 USD on your Additional Services balance:
https://www.sierrachart.com/usercp.php?page=AddAccountCredit
When that is done, let us know and we will go on to the next step.
Date Time Of Last Edit: 2016-03-11 21:50:23
[2016-03-12 00:06:47]
Ok. Added $10. I have more than 500 USD in Ameritrade account.
[2016-03-12 00:27:30]
Go to this page:
https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures
Click on the link that says Agreement needs to be signed.
Complete the agreement and let us know when that is done.
[2016-03-12 00:52:14]
Agreemnt signed.
-Abdulla Mangalore
[2016-03-12 17:59:25]
The CME Group exchange has been activated on your account now.
Follow through the instructions here to set Sierra Chart to work with your TD Ameritrade account:
https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions
You can open the futures charts through File >> Find Symbol.
Starting Sunday evening you will start to receive real-time data for them.
[2016-03-13 08:21:56]
Thanks.
Will the chart update be automatic and real-time once it is opened. ?
Abdulla Mangalore
[2016-03-13 09:22:22]
Yes it will be.
[2016-03-14 18:48:25]
It does not auto refresh. Also when I refresh manually there is a lag of 15 minutes or so. Please check,
Abdulla Mangalore
[2016-03-14 18:56:54]
You must set Sierra Chart to connect to your TD Ameritrade account. Refer to the instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration
[2016-03-17 19:27:09]
Is there any service which will give real time feed for S&P 500 stock please ?
Abdulla Mangalore
[2016-03-17 19:52:53]
First, can you confirm you are receiving real-time data for the ES June 2016 S&P 500 futures?
Want to make sure that is working properly for you.
Date Time Of Last Edit: 2016-03-17 19:53:03
[2016-03-17 20:08:38]
Yes that is wotking correctly now.
[2016-03-17 21:25:07]
So did you want to get real-time data on all of the stocks that are part of the S&P 500?
[2016-03-17 21:42:07]
No just the index stock SXP
[2016-03-17 22:11:33]
So you want the real-time data feed for the S&P 500 cash index itself?
[2016-03-17 22:25:34]
Yes please.
[2016-03-18 16:27:45]
Go to this page and activate the S&P Indices exchange:
When that is done, restart Sierra Chart.
Open a chart for the symbol $INX through File >> Find Symbol.
