Date/Time: Fri, 27 Dec 2024 02:16:12 +0000
New Spreadsheets
View Count: 640
[2016-03-10 18:32:57] |
George - Posts: 60 |
I am able to use Copy Formula to transfer formulas,text color and cell color fine. Is there a way to transfer Column Widths from one sheet to another sheet, within the same spreadsheet, or to make a template of a spreadsheet? |
[2016-03-10 18:47:10] |
No. This is not supported but you can copy an entire Spreadsheet with File >> Save As.
