Date/Time: Thu, 26 Dec 2024 11:37:04 +0000
Question About Calculated bars study
View Count: 1468
[2016-03-10 17:07:20] |
Locomotora - Posts: 14 |
Ok, I am trying to accomplish something but I cant get it to work. My set up is this - Point and figure chart. - Volume distribution paint bar study. - Number bars calculated values study. What I want to get is within any bar if there is a bis ask difference imbalance (I will set the condition) and put a mark on it, like a dot, or a star, or anything that I can see it. Is there any study that can help my in doing this? Thanks |
[2016-03-10 18:11:11] |
We do not recommend using the Numbers Bars Calculated Values study with a Point and Figure chart. Instead use Reversal Bars: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#ReversalBarsChart Are you asking about a difference between the Ask Volume and Bid volume for an entire chart bar? Or a particular price level? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-10 18:12:09
[2016-03-10 18:22:18] |
A particular price level. i dont really need the Numbers Bars calculated in my case.
[2016-03-11 16:02:23] |
disregard help request. i figured out
