Date/Time: Fri, 27 Dec 2024 16:16:02 +0000
Alert Sound Folder
View Count: 932
[2016-03-10 16:44:48] |
trader1 - Posts: 128 |
Hi, I was wondering if you guys could make it so that we could specify a certain alert sound folder. That way we wouldn't have to navigate to a preferred folder every time we want to select an alert. Thanks. |
[2016-03-10 17:32:45] |
Not really at this time. We already have a very long to do list and feature requests like this are not easily implemented and inevitably lead to problems for other users when they are introduced and ongoing support. You really just need to put the sound files inside the Alerts Folder and this is what we require. Thinking about this some more, the decision is we will not add this feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-10 17:34:07
