Date/Time: Fri, 27 Dec 2024 16:50:56 +0000
Midpoint data for options from IB
View Count: 603
[2016-03-10 16:26:37] |
Robson - Posts: 76 |
is it possible to download options data as Midpoint for Options from Interactive Brokers? SPY-OPT-20160311-198-P-SMART-100-USD this works only for trades, -BAAVG maybe? |
[2016-03-10 17:30:54] |
Yes you can. Use this: SPY-OPT-20160311-198-P-SMART-100-USD-BAAVG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
