Date/Time: Fri, 27 Dec 2024 16:04:13 +0000
Can't Change Rollover Date
View Count: 725
[2016-03-10 04:56:16] |
skelcap - Posts: 139 |
Hi I have ES futures with Date Rule Rollover and the default setting is 8 days before the 3rd Friday (3/18) which has it rolling at 12 midnight on 3/8. I want it to roll 1 day later so I change it to 7 calendar days and reload the chart but there is no change. Am I supposed to delete all data and download?
[2016-03-10 05:03:09] |
That's funny, now midnight has passed it works!
[2016-03-10 05:08:04] |
But I still want to see the old Mar16 contract for now until the volume picks up in Jun16. So I change 7 days before 3rd frid to 6 days and I have the same problem again, no impact. How can I make this happen?
[2016-03-10 05:44:34] |
Duh ok answered my own question, just need to unselect Automatic Rollover and set the symbol equal to the Mar16 contract
[2016-03-10 06:31:29] |
Yes this makes sense if you want to continue to see the March 16 contract. The rollover rules are only there for the purpose of loading in prior historical contracts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-10 06:32:00
[2016-03-10 11:27:38] |
And is it possible to see a longer-term daily chart with the prior contracts but the final one still being Mar16?
[2016-03-10 17:08:48] |
Yes of course. Open a Historical Daily chart for the March 16 contract following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#OpenChart And follow the instructions here to use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts And make sure that Chart >> Chart Settings >> Automatically Rollover Futures Symbol is unchecked. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-10 17:09:37
