Date/Time: Fri, 27 Dec 2024 00:20:45 +0000
Relative Volume
View Count: 729
[2016-03-09 23:45:51] |
User788311 - Posts: 29 |
Hello, would you please help me? I need to have Relative Volume values below the main graph as a text in a row instead of lines or bars. Is that possible? Regards, Richard |
[2016-03-10 03:54:21] |
Not unless you custom develop your own study that does this. You could do something like this by using the Value of Subgraph Draw Style: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-10 08:02:50] |
Thank you. Yes, I tried this tool, however the text is "jumping" up and down according to the value. |
[2016-03-10 10:07:24] |
We will develop a solution for this. Check back in about three weeks.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-10 10:08:13
[2016-03-19 01:15:27] |
Kinobe - Posts: 86 |
I am interested too.
