Date/Time: Fri, 27 Dec 2024 16:07:54 +0000
Real time SP500 index
View Count: 661
[2016-03-09 15:50:20] |
User982736 - Posts: 46 |
I just purchased the exchanges I need. I thought $spx was realtime, but it is not updating on my chart. Am I mistaken about this index? |
[2016-03-09 15:58:02] |
Use the symbol $INX instead. $SPX requires the CBOE exchange.
[2016-03-09 16:00:32] |
Thanks.
