Date/Time: Fri, 27 Dec 2024 16:34:33 +0000
No live update on charts ?
View Count: 675
[2016-03-09 15:32:13] |
User512347 - Posts: 5 |
My charts are not having a live update occur for some reason? They are stuck only when I update manually and even then I'm about 10-15 minutes behind actual time.
[2016-03-09 15:56:43] |
What is one of the symbols that is not updating in real-time?
[2016-03-09 16:08:54] |
Any stock stock symbl such as NFLX, Amzn, CMG, etc. If when I change a symbol in the chart it updates it 20 minutes behind real time. Its lagging real time by 20 minutes. Not sure why this delay, it use to update instantly or live.
[2016-03-09 16:16:30] |
For stock symbols you need to activate the "US Equities" exchange which you currently do not have: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures Also the delay time should be 15 minutes and not 20 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-09 16:17:00
