Date/Time: Fri, 27 Dec 2024 16:25:38 +0000
Which data feed to enable to get foriegn markets
View Count: 792
[2016-03-09 14:16:58] |
dd45 - Posts: 41 |
Which data feed do I need to enable to get streaming data for FTSE, DAX, nikkei, etc contracts? Thanks!
[2016-03-09 16:05:14] |
Did you require the cash prices for these markets? Or futures?
[2016-03-09 16:50:32] |
dd45 - Posts: 41 |
futures, but what would both solutions be?
[2016-03-09 18:40:26] |
For the FTSE100 you need the LIFFE exchange. For the DAX you need the EUREX exchange. These can be activated here: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures Although the LIFFE exchange is very expensive. For the Nikkei 225 on the CME, this is already available to you and the OEC symbol is: NKD?# Real-time cash prices for these indexes are not available from the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-09 18:40:52
