Date/Time: Fri, 27 Dec 2024 16:51:30 +0000
Chart Trade Mode > Confirmation for Order Modification?
View Count: 733
[2016-03-09 09:46:27] |
User51760 - Posts: 108 |
Hello Support Team, is it possible to enable confirmations (popup windows like on the DOM) for order modification in chart trade mode? Thank you for your support, Best, Chris |
[2016-03-09 09:51:16] |
Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
