Date/Time: Fri, 27 Dec 2024 16:34:27 +0000
Info Study Alert - popping and has a sound alert to it that I wish to get rid of
View Count: 696
[2016-03-08 18:28:10]
AP - Posts: 117
Hi -
Please see below the attached image.
http://www.sierrachart.com/image.php?l=1457461526483.png
There is this info type alert that has a sound alert attached to it. Not sure how it has crept into my set up. I wish to get rid of it. Please, please help. It is very intrusive.
Thanks.
[2016-03-08 19:21:30]
Scroll the Alerts Log towards the right side and tell us exactly the text you see in the Alert Text field for that particular Info Alert Message.
[2016-03-08 20:28:33]
AP - Posts: 117
http://www.sierrachart.com/image.php?l=1457468628961.png
See the above link now.
Just so happens that an applause alert has sneaked into this numbers bars study and has +delta slope above 1000 in value will trigger it.
Now in checking inside the study, nothing that I did is triggering it. Not sure what is triggering it in the first place.
[2016-03-08 20:32:15]
AP - Posts: 117
I tried removing the study and adding it back again and it still did not work.
[2016-03-08 20:32:37]
AP - Posts: 117
Meaning it still holds this applause alert.
[2016-03-09 04:25:23]
That is a Chart Drawing alert.
Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html#DisablingAlertSounds
We made some improvements in a recent release to be able to improve locating these in the Tools >> Manage Chart Drawings Window. The chart drawing numbers are now listed there in recent versions.
[2016-03-09 14:56:31]
AP - Posts: 117
Thank you guys!
Appreciate your help.
