Date/Time: Tue, 14 Jan 2025 02:28:57 +0000
futures data question
View Count: 627
[2016-03-08 17:34:05] |
User314976 - Posts: 4 |
Hello, i have Package 5 and my question is - Have I an access to live futures data with Package 5 ? and if the answer is yes-where i can find this chart on the platform ? Thanks |
[2016-03-08 18:13:29] |
For a proper explanation to this, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php You are also running an older version of Sierra Chart. Update Sierra Chart by following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
