Date/Time: Fri, 27 Dec 2024 15:36:29 +0000
VbP Study - Ticks Per Volume Bar
View Count: 863
[2016-03-08 16:40:33] |
User609105 - Posts: 28 |
I cannot seem to get this value to <5 on CFD Indexes. I have checked the electronic manual and it indicates that values 1 & 2 are possible. Do I need to do something more then input the number in the field? When I do it automatically re-selects 5. No problem going higher. Or is 5 the minimum for indexes? |
[2016-03-08 18:12:03] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#TicksperVolumeBar You need to check the Volume at Price Multiplier in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-10 11:39:18] |
Got it, thank-you
