Date/Time: Thu, 10 Sep 2026 03:41:58 +0000
TPO Count
View Count: 1531
| [2016-03-08 15:05:06] |
| User884307 - Posts: 173 |
Hi, I missing something somewher but in MP charts could tell me how to display the total TPO count i.e. tpos's above POC and tpo's below POC in the format like 45/69 for example Cheers |
| [2016-03-08 19:01:39] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-08 19:42:11] |
Many thanks for that, is there anyway to plot for previous profiles ? cheers |
| [2016-03-08 20:30:39] |
Yes of course. The documentation explains this: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation Use the Tool Values Window and the Chart Values tool. Check the documentation again for all of the information and links. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-08 23:31:14] |
hi, i have done that but i cant get a tag for each profile to display somewhere the tpo count above/below the poc cheers |
| [2016-03-09 00:02:45] |
The TPO Count data displays in the Window >> Tool Values Window.
| [2016-03-11 17:05:34] |
Hi ok, getting used to the mouse hover over profile to get info but would there be any chance this could be ammended to update in real time, its a bit annoying to keep having to move the mouse away from profile then back again to get the latest information Many thank :-) |
| [2016-03-11 18:35:51] |
In that case use the Window >> Chart Values Window to display the changing data for the last TPO Profile displayed. It will only be the very last TPO Profile which will have changing values. Also it would take literally only a one pixel movement of the Pointer to cause the Tool Values Window to update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-11 18:36:38
| [2016-03-16 16:37:53] |
Hi, on the Window >> Tool Values Window would it be possible to include Volume Delta above/below POC ? cheers |
| [2016-03-16 16:41:52] |
.... i need to add also in MARKET PROFILE VbP in a Market profile value in Window >> Tool Values Window just show zero's cheers |
| [2016-03-16 17:51:15] |
What is meant by "Volume Delta"? To see the text information for the Volume by Price study in the Chart Values windows, requires that you use the Volume by Price study on a chart without a TPO Profile chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-16 19:10:45] |
Hi, difference beween ask and bid . there is already a line showing volume above/below POC but would be useful to have the delta of the same cheers |
| [2016-03-17 15:22:11] |
Hi, just wondering if this could be implemented? cheers :-) |
| [2016-03-17 17:07:58] |
Yes but we do not know when we can add this. We will put it on the to do list but we would expect it to be months away.
