Date/Time: Fri, 28 Feb 2025 18:41:03 +0000
PORTFOLIO SCALING AND ALLOCATION ?
View Count: 1523
[2016-03-07 23:24:05] |
User367949 - Posts: 25 |
Hi There, I would like to have a Watchlist/ Quote Manger of the most traded futures list like this - http://www.barchart.com/commodityfutures/leaders?type=ma Ranked by Volume, I would like to code the automated strategy so that it allocates 10% of the trading capital for that trading day. So it Automatically allocates to the most traded list and decide's where to allocate the capital 1st by volume eg /ES with the correct settings I have coded in for that strategy eg 5min time frame and max contracts 100 with out slippage for example. Say the 10% amount allocated for any trading day has grown and I have some left over to allocate to the next most highly traded futures say the /CL now it builds up till /CL is at maximum allocation setting eg 50 contracts on a 15 min time frame. How do we achieve this with Sierra? It will be coded in a custom study to be automated Thanks A Date Time Of Last Edit: 2016-03-07 23:55:02
[2016-03-08 16:50:53] |
Any Advise SC ?
[2016-03-09 04:22:57] |
We can only give you links to the documentation of the areas of the Advanced Custom Study Interface and Language which we think would be helpful: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html http://www.sierrachart.com/index.php?page=doc/doc_ACSILRefOtherTimeFrames.php http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#AccessingCurrentSymbolDataForOtherSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-09 14:47:35] |
Thanks for the links, I have moved from Multicharts to Sierra you can do this on multi charts with quote manager. My question is to Sierra Charts Platform Developer is this possible with Sierra? Thanks A |
[2016-03-09 16:24:21] |
The Quote Board does support sorting by columns which can be the "Volume" column: http://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuoteBoard Sorting is not documented but it is easy to set up simply by left clicking on the Volume column header. Does that answer the question? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-09 16:24:33
[2016-03-09 18:32:00] |
Kind of - so i can code as state above and it will work ?
[2016-03-09 18:46:07] |
This is all certainly possible but it does take programming to make it all work. You may want to find a programmer here to help you: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-25 02:56:41] |
Shores2021 - Posts: 26 |
Hello, I am trying to monitor multiple instruments that are traded by SC spreadsheet for trading. How can I see a simplified sheet that shows all current Positions by instrument, lot size, entry price etc.. I am just looking to be able to have all traded instruments that arw traded across a dozen charts and corresponding spreadsheets tracked on one simple sheet for a visual orientation what I am long/short/instrument/size/entry/P&L. I am sure I am missing a simple way to achieve this on SC. Thank you very much. Date Time Of Last Edit: 2021-08-25 03:41:50
[2021-08-26 07:48:52] |
Refer to: Trading Information Windows: Trade Positions Window This information is not provided through a Spreadsheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-26 07:48:59
[2021-08-30 19:00:56] |
Hello, Is it possible to export data from the SC spreadsheets to excel in real time? For example, I would like to be able to monitor all of my live positions from several spreadsheets into one spreadsheet on SC and then have that information exported in real time to excel or google spreadsheet. Please advice. Thank you very much. |
[2021-08-31 14:53:12] |
John - SC Support - Posts: 38280 |
You would have to program that interface to get the data from out of the Sierra Chart spreadsheet and then into another one. Refer to the information starting at the following for how to programmatically access Sierra Chart spreadsheet data: ACSIL Programming Concepts: Referencing Data from a Sheet within a Spreadsheet For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-01 18:50:47] |
Also refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#PeriodicallySaveSheetAsTextInMinutes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-01 18:51:19
