Date/Time: Fri, 27 Dec 2024 01:35:16 +0000
Tracking crosshairs
View Count: 715
[2016-03-07 21:06:40] |
tellerbe - Posts: 109 |
My chart is set up such that price is on half a page and studies on the other half. I would like my crosshair tool to track on both sides of the page. Hope I am clear as to what I want
[2016-03-07 21:13:43] |
It sounds like you want to use the Global Cursor feature which is documented here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
